Water Pump Belt Tensioner
Results 1 to 10 of 10
Cadillac Seville / Cadillac Eldorado Forum Discussion, Water Pump Belt Tensioner in Past Cadillac Vehicle Discussion; Can anyone tell me if the water pump tensioner assembly is still available for a 93 Northstar? Don't need one ...
    9302Eldug is offline Cadillac Owners Fanatic
    Automobile(s): 93 and 02 Eldorado
    Apr 2012
    Oakley CA
    60
    226
    Can anyone tell me if the water pump tensioner assembly is still available for a 93 Northstar? Don't need one now but if they are getting scarce I would like to have one just in case. Blame it on my OCD!
    RJ
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,875
    Re: Water Pump Belt Tensioner
    You don't need the whole tensioner - the pulley is what fails and it is available and replaceable separately. ~$24.
    Look at RockAuto, your car, engines, belt drive, the 3-rib pulleys. Gates is just fine.
    Talk to Chris in parts at Rippy Cadillac over there >>> N - S business hours EDT.
    Pictures of the water pump drive parts, removed pulley and diagrams in my albums. Community tab, Albums, the red Seville.
    EDIT: Looked in RockAuto - 3-rib belts available, but do not see either a complete tensioner or a pulley for a 1993 Northstar. Check out listings for a 1993 Northstar Seville or talk to Chris. Maybe www.gmpartsgiant.com. Also, NAPA has the (later) pulleys - try there.
    Last-ditch effort: Remove the existing pulley, carefully remove the grease seal on one side, wash it all in mineral spirits, blow dry and repack with wheel bearing grease. Fit the seal carefully, making sure the small outer retainer lip is in the pulley groove all the way around. My pictures.
    Feb 2006
    56,875
    Wut ???
    Did you talk with Chris - at Rippy Cadillac parts over there >>>>>>>>>>>
    69
    82,286
    The '93 & '94 are different than the rest of the Northstars in many ways, but I never thought there was a reason for the WP tensioners to be different.
    Follow Sub's advice.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    IIRC, it's discontinued
    The Gold's Avatar
    The Gold is offline Cadillac Owners Fanatic
    Automobile(s): 92 El Dorado
    Jul 2010
    San Francisco
    125
    Pick n pull ?
    Apr 2012
    Oakley CA
    60
    226
    I suppose that I am lucky, There is a Cadillac only dismantler about 3 miles from me, They have just about everything, For A Price!
    Old Hippie is offline Cadillac Owners Member
    Automobile(s): 1993 Allante
    Aug 2014
    61
    7
    Get two, I need one!
    RussBarnes's Avatar
    RussBarnes is offline Cadillac Owners Member
    Automobile(s): '93 Allante
    May 2014
    Middle Tennessee
    7
    FYI, my '93 crapped out last Tuesday. I got on the web and found some good information, some used ones on eBay, but no new ones. I tried Rock Auto and several other links, but in Canada I found a lead to Northstar Performance dot com
    group that has new ones in stock and not much more expensive than the most expensive used ones on eBay. You tell me, since my OEM went 57,000 miles, how many miles does that used one have and how long before I need another? And
    since it seems to be assembled without fasteners, how does one take it apart to lube, replace pulley or do anything?
    69
    82,286
    I replaced mine last year at just over 100K and while I was at it I figured I'd do my daughters (at around 140K-150K).
    yours failed prematurely.
  13. Remove Advertisements
