2003 SLS A/C issue
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2003 SLS A/C issue in Past Cadillac Vehicle Discussion; I have a problem with my A/C. When it is on the passenger side 2 vents blows ice cold air ...
    jesserb is offline Cadillac Owners Member
    Automobile(s): 2003 SLS
    Dec 2011
    41
    14
    2003 SLS A/C issue
    I have a problem with my A/C. When it is on the passenger side 2 vents blows ice cold air BUT the driver side is blowing air like it is the heater. Any suggestions?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,263
    Re: 2003 SLS A/C issue
    Quote Originally Posted by jesserb View Post
    start with checking for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    to diagnose AC problems -
    you need to connect a quality set of guages -
    then post BOTH the HIGH pressure readings -
    and the LOW pressure readings -
    along with the ambient - outside - air temp -
    and the air discharge temp at the center AC vent -
    with the temp set at 60* and a medium speed fan -
    68
    81,755
    Is the drivers side "hot" or just warm? Ambient or warm is a sign of low refrigerant. Not quite low enough to set a DTC though.
