1995 Eldorado warning lights/message/voltage
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1995 Eldorado warning lights/message/voltage in Past Cadillac Vehicle Discussion; 95 eldorado etc has decreasing battery voltage, initial 13.8 after warm up drops to 13.4 at red lights in Drive ...
    roachetim is offline Cadillac Owners Member
    Automobile(s): 95 eldorado etc 03 CTS
    Jul 2013
    56
    4
    95 eldorado etc has decreasing battery voltage, initial 13.8 after warm up drops to 13.4 at red lights in Drive with brake peddle depressed will drop to 11.9 and increase when I start to move. Asked question on fixya.com, they had me disconnect abs to see if battery volts halds steady ( it did not ) but now Anti-lock brake light is on and traction control disabled indicated, ( abs was reconnected ) How do I reset these ?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,349
    Re: warning lights / message
    Quote Originally Posted by roachetim View Post
    either your idle is set too low -
    should be 650 - in gear - with AC on -
    OR the alternator is failing -
    can't imagine WHY they would suggest that -
    because the ABS was unplugged -
    there are probably fault codes now set -
    you will need to clear the codes - HOPEFULLY -
    that will take care of the problems -
    to check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Jul 2013
    56
    4
    Got all warning lights to reset, was still seeing battery voltage drop, as described previously, so I replaced alternator. Problem continues. Battery is only 9 months old and shows 12.8 via dc volt test. battery volts on dash reading, upon new alternator 14.1start, but during drive dropped to 13.4 and decreases at stop lights.
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    Same here, alternator tested ok (at az), battery ok.
    Figured two things: first that the regulator wires (the plug at the alternator) are quite thin and prone to screw up output voltage, I learnt that after having somebody rip them off accidentally (voltage went up to 18V at that moment) and to have to re wire. What I experienced was that depending on how careful I did the connection, voltage would improve or get worse...
    And second that in my car the voltage shown on the dash is actually 0.5V below battery voltage, so I stopped worrying about it, since battery is charging ok anyways. Actually I did think that a new alternator would take care of that, but seems to not be the case, good to know though...
    Roofy is offline Cadillac Owners Member
    Apr 2014
    3
    Re: 1995 Eldorado warning lights/message/voltage
    The 96 Eldorado has traction control light on and abs light on. The AC turns off for engine protection and the heat turns on and off intermittently. Shift indicator on dash flashes when applying brake. I cleaned the key and attempted to clean the ignition switch the best I could to see if that is a problem. After pulling the battery cable to have it reset, the ac starts to work but soon the dash gear indicator light flashes and the the you hear the compressor turn off and the message comes across indicating it shut off the ac to protect the engine. The car starts without issue even though the theft protection warning comes on saying that it may not restart. I have driven it and it performs fine but if I hit the brake the gear indicator will start flashing and it feels like power is draining. I had the battery and the alternator checked by Advance Auto and that checked out good. No codes were coming up on their check either. But a list of codes do show up when checking the system on the dash. Oh yes the lights on the climate control system come on and off too intermittently.
    All of this started a few days ago and I have tried all the suggestions except the chip on the key.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I'd suggest starting your own thread (or a mod can move your post to a new thread for you). List all of the codes you pulled, AND THEIR DEFINITIONS.
    Apr 2014
    3
    Thank you I will do that just trying to get started in here.
  10. Remove Advertisements
