2003 STS very bouncy
Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2003 STS very bouncy in Past Cadillac Vehicle Discussion; I just bought a 2003 STS and it is very bouncy in rear it seems on highway or just driving ...
    speedydog is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    43
    I just bought a 2003 STS and it is very bouncy in rear it seems on highway or just driving ,I thought this had air shocks ,I have no trouble codes is my air ride system bad or shocks it has 71000 miles on it how can I check ?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: 2003 Seville STS very bouncy???
    The only air component is the rear leveling system...The shocks have bladders that fill up when extra weight is added to the rear seat or trunk.
    You can test this system by starting the car, opening the trunk, and sitting on the trunk lip...After a few seconds you should hear the compressor kick in and feel the rear rising, once you hop off you should hear the air being released and notice the rear dropping slightly.
    If it's bouncy I would inspect the shocks for leaking fluid...All 03 STS's are equipped with magnetic ride control struts/shocks...If they're leaking that fluid they're shot and need replacing...Get ready for some sticker shock!
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,874
    Quote Originally Posted by speedydog View Post
    do the bounce test -
    go to the rear - easier if you open the trunk -
    put your knee on the trunk ledge -
    and bounce the rear up and down several times -
    when you stop bouncing - the car should stop also -
    if it continues to bounce - either the rear shocks are shot -
    or they are malfunctioning - or the control module is defective -
    you DO have Electronic Level Control in the rear -
    it is a system that utilizes air bladders built into the rear shocks -
    to maintains proper ride height -
    regardless of the weight in the back seat and/or trunk -
    the ELC system has absolutely NOTHING to do with it being "bouncy" -
    it simply prevents the rear end from sagging with a heavy load in the rear -
    that being said - the rear shocks COULD be worn out - or defective -
    your STS has a very unique - read VERY EXPENSIVE - suspension system -
    FE3 / F55 -
    the rear shocks are - with the best prices -
    ACDelco 580323 RIGHT - $579 - with free shipping -
    autopartstomorrow.com
    ACDelco 580325 LEFT - $522 - with free shipping -
    Oct 2007
    43
    Is there any aftermarket way to go without using their shocks to bypass the system ?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    There is no bypass for F55 cars.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    is there any aftermarket way to go without using there shocks to bypass the system
    unfortunately NO -
    there is just no way to get around the F55 suspension system -
    the passive system in the SLS - and this WILL make you cry -
    the rear shocks are $58 for the pair - with free shipping -
    oh - the front struts for your car -
    ACDelco 580245 - $565 each - with free shipping -
    Cadillac Kid03 likes this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    Re: 2003 STS very bouncy
    Yep - The entire car and drivetrain is tuned for the F55 Magnetic Ride Control system. Our cars were the test mules for the later Corvette and Ferrari Lord/DELPHI systems - and those systems are now in performance Cadillacs across the line.
    The 2003 STS listed for about $55,000, and that's where the maintenance costs will fall - very, very few workarounds.
    There is NO "air suspension" - the rear shocks also help control rear ride height changes due to extra weight in the trunk and back seat.
    bwv565 likes this.
    Oct 2007
    43
    Quote Originally Posted by Submariner409 View Post
    is it possible I don't have the f 55 system how can I check
    Feb 2006
    57,174
    Look on the RPO sticker under the spare tire cover............. F55
    F55 began on 01-15-2002 and ended in 06-2003 when the last STS rolled off the Seville lines in Hamtramck.
    Your STS is a F55 MRC car. No doubt.
    bwv565 is offline Cadillac Owners Enthusiast
    Automobile(s): HAD a miserable Catera and even worse 2003 STS
    Jan 2013
    Toronto
    603
    Same issue with mine. Check the struts and shocks.
    Oct 2007
    43
    UGH you guys are killing me I guess last question what is my aftermarket options for the shocks is it only ac delco or does Monroe or Gabriel make ones compatible
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 Honda Accord LX. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    27
    3,718
    There is NO aftermarket for the Magneride shocks. You can only purchase them from GM. Check eBay as they have some good deals from time to time.
    Cadillac Kid03's Avatar
    Cadillac Kid03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Cadillac Seville SLS
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    Quote Originally Posted by basscatt View Post
    unfortunately NO -
    Seeing $58 for a pair of struts for my car makes me feel good.
  16. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    as I said in post #6 -
    there are no options - period -
    the ONLY rear shocks that will work on your car are the
    and the front struts - $563 each - with free shipping -
    OR
    http://www.amazon.com/gp/product/com...2003&carId=001
  17. #15
    Sep 2003
    Metro ATL
    4,854
    Obviously your parts shopping is driven by price. Not an unreasonable position to take with a soon to be 14 year old car.
    You can cheap out and restore a non-bouncy ride by installing struts and or shocks designated as "NON-ELECT" by Monroe and possibly Gabriel. In other words, parts that are intended as aftermarket substitutes for a 1998 to 2004 Seville SLS model that did not come from the factory with either F45 or F55 suspension. And you have not mentioned if your RPO sticker indicates F55.
    Since you have no trouble codes or messages (post #1), we can assume the struts and or shocks are simply worn out due to age or miles or some combination of both.
    Narrow the failed parts possibilities down a little. Is the front end bouncing too often after travelling over a bump/dip in the pavement?
    Or only the rear end?
    Or both?
    Just know that installing NON-ELECT struts or shocks on your STS will not restore all the gee-whiz functionality to your suspension. But it will dampen the annoying and potentially dangerous bouncing. However, you will see the SERVICE SUSPENSION SYSTEM message at every engine start cycle unless you install resistors to simulate the presence of the electronic portion of the strut or shock.
    The message can be defeated (popular 'opinions' are not technically accurate) if it becomes too much of nuisance to deal with.
  18. Remove Advertisements
