97 STS AC/ over pressure?
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 97 STS AC/ over pressure? in Past Cadillac Vehicle Discussion; My ac would work then not work. So I thought I would charge it with some Freon. I connected the ...
    zek4964 is offline Cadillac Owners Fanatic
    Automobile(s): 08 cts 68k, 07 STS-V 15K, 97 Sts 160k
    Jun 2010
    Rochelle IL
    302
    My ac would work then not work. So I thought I would charge it with some Freon. I connected the bottle up but the system pressure was off scale high over 80 PSI. The compressor was not kicking on and off either. I am guessing because of the high pressure cut out switch being in.
    I bleed the pressure down to 50 PSI then tried to get the compressor running again. The AC unit does not seem to be turning on.... The system will not take in any Freon when it is over pressure either. But over pressure is a sign of low coolant correct....?
    My main concern now is the compressor is not turning on.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    What are our ac codes? If compressor will not turn on, you have codes.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,374
    Re: 97 STS AC/ over pressure?
    Quote Originally Posted by zek4964 View Post
    if the compressor is NOT running -
    the pressure reading you are seeing is "static" pressure -
    which means nothing - except there is SOME freon in the system -
    the pressure readings that DO have meaning -
    is when the compressor IS running -
    IF the system is low - a trouble code should be set -
    and that trouble code will disable the compressor - to protect it -
    the code must be cleared before the compressor will work -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    68
    81,928
    I seem to recall normal static pressure of about 70 psi. Your 80 might not be to far off, but like Bass said, that's irrelevant. With the compressor disabled you will NEVER get it to draw in refrigerant and the fact that you bled off refrigerant, most likely your are now in fact low.
    Jun 2010
    Rochelle IL
    302
    Yeah i have the book and codes i will check it what codes will it be? Pcm or other codes?
    68
    81,928
    A/C related should be B (Body) Codes.
  9. Remove Advertisements
