1996 STS - plugs, wires replaced - hesitation
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1996 STS - plugs, wires replaced - hesitation in Past Cadillac Vehicle Discussion; I recently started having a slight hesitation when trying to accelerate so i used my pocket scanner and got error ...
    god of tazz is offline Cadillac Owners Member
    Automobile(s): 1996 Caddilac Seville STS
    Jul 2013
    5
    I recently started having a slight hesitation when trying to accelerate so i used my pocket scanner and got error code p0301 which is a misfire in cylinder 1 so I replaced all spark plugs the spark plugs as the previous owner hadn't done them as recently as the wires i still had the issue so i replaced the ignition coil the controls that cylinder as upon inspection it had a small crack in the plastic casing. I still had the issue so i went ahead and replaced the spark plug wires im still having the same code but now even though i havent moved it i now have p0325 as a code which is a knock sensor code any idea what could be causing this once i replaced the ignition coil it stopped hesitating when backing up and it cranks normally.
    Edit ICM still in good shape but for good measure i have a neighbor who has the Eldorado same year sane motor and put my icm on his no issue so now its back in place on mine and i double checked all connections to it and number 1 cylinder and recheck number 1 plug and it is not fouled looks very clean
    69
    82,180
    Re: 1996 STS - plugs, wires replaced - hesitation
    If you replaced the plugs, wires and coils and still have a misfire, the only thing left is the ICM.
    Jul 2013
    5
    deleted
    fivepointohman is offline Cadillac Owners Member
    Automobile(s): 98 Eldorado ( previously 96 SLS )
    Jul 2013
    36
    44
    Fuel injector bad or clogged?
    69
    82,180
    Possible, but not probable.
    Jul 2013
    5
    Ok update I went ahead and pulled apart the intake so that i could go ahead and replace the knock sensor i pulled a code for. I put everything back together and and now i only have an intermittent issue with the heated oxygen sensor bank 1. I only seem to get the check engine light for that if I get stuck in a lot of traffic on days where the ambient temperature is 100 degrees Fahrenheit. Also i have already replaced all the injectors when I first got the can as it wasn't getting any fuel to cylinder 4.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,606
    Are your coil-to-plug wires connected like this ???
    Jul 2013
    5
    Quote Originally Posted by Submariner409 View Post
    I was able to get the issue with the hesitation resolved turns out i also had a few vacuum line that disintegrated. Shortly after fixing that I started having a severe overheating issue issue after letting my brother in law borrow the car.
  11. Remove Advertisements
