Stabilty Sys, Traction Control, ABS lights
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Stabilty Sys, Traction Control, ABS lights in Past Cadillac Vehicle Discussion; I ran the codes and was getting TCS C1225 and 1226 which suggests front hubs. I replaced the hubs and ...
    92WHTSTS's Avatar
    92WHTSTS is offline Cadillac Owners Fanatic
    Automobile(s): 99 Eldorado ETC
    Jan 2011
    278
    I ran the codes and was getting TCS C1225 and 1226 which suggests front hubs. I replaced the hubs and sometimes upon take off after a stop, I still hear a grunting noise immediately followed by the message in the title on the DIC. What could it be now? I've been repairing everything as needed, but this car is starting to irritate me.
    69
    82,155
    Re: Stabilty Sys, Traction Control, ABS lights
    If those codes are wheel speed sensor related and you changed both front hubs I can only suspect it is a bad connection, wire or the EBTCM.
    92WHTSTS's Avatar
    Jan 2011
    278
    Both of those codes I listed are in history. A guy I know has one of those code readers that the GM mechanics use, and after he used the reader, he said the front left hub was bad and suggested I change the hubs on both wheels. If it is the EBTCM as you suggest, how expensive is that to replace?
    69
    82,155
    The EBTCM is quite expensive, but if you look online I believe there are a few places that rebuild them.
    F.Y.I.
    Your car has a built in code reader.
    92WHTSTS's Avatar
    Jan 2011
    278
    Thx Ranger. I know it has built in reader..... He is a retired mechanic and just decided to use his I guess.....
    69
    82,155
    OK, just wanted to be sure you where aware of it.
  9. Remove Advertisements
