Results 1 to 7 of 7
Thread: 97 Seville stumble
    sdt1985 is offline Cadillac Owners Member
    Automobile(s): 1997 Seville SLS
    Jun 2009
    Texas
    53
    97 Seville stumble
    My 97 Seville has started a slight rough idle and a "stumble" on acceleration. I've been through the plug wire/spark plug hesitation. This is something different. This feels like a carburetor flooding. Any ideas?
    I checked for codes and there were none
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Did you use a scan tool, or pull codes through the DIC? Any history codes?
    Jun 2009
    Texas
    53
    Re: 97 Seville stumble
    There were history codes. I didn't write them down.
    I pulled them through the DIC
  5. #4
    69
    82,262
    What's your fuel pressure?
  6. #5
    Jun 2009
    Texas
    53
    The history codes are P0174, P1602, P1632 and P1644. We have been having issues with the VATS key not reading. Could the P1632 Theft Deterrent Fuel Disable Signal Received be doing it?
  7. #6
    rodnok01's Avatar
    Feb 2012
    NC
    6,697
    Vats will keep it from starting not cause running issues.
    Post definitions with codes and if current or history.
    Bypass vats or get new key before it strands you.
  8. #7
    Jun 2009
    Texas
    53
    I did get a new key... It since developed a strange acting overheat problem. Didn't act like a thermostat or a leak or a clogged radiator. It would just flow out of the overflow after you drove it a fairly long distance. Thinking the worst, I used a CO2 block tester with negative results. (WHEW!!!).
    I decided to go after the "miss" thinking it was overworking the engine causing the overheat. I dug out my old inductive timing light and checked the individual wires. Some of the wires were eratic so I threw a set of wires at it. With no improvement I tried replacing the coils. No more hesitation and the cooling problem seems to have disappeared.
    Gotta love these cars. Nothing acts normal.
  • You may not post replies
