New to Cars in General, have a 95 Eldorado, plethora of problems - Page 9
Page 9 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 121 to 135 of 256
Like Tree42Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, New to Cars in General, have a 95 Eldorado, plethora of problems in Past Cadillac Vehicle Discussion; Originally Posted by MoistCabbage 220 is nothing to be concerned with, the fans don't even go to low speed until ...
  1. #121
    rkeating09 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Jul 2013
    26
    105
    Re: New to Cars in General, have a 95 Eldorado, plethora of problems, help?! D:
    220 is nothing to be concerned with, the fans don't even go to low speed until 224 (and high at 236).
    Running the engine at ~3,000 RPM for a minute or so might help purge the system quicker.
    Will do. Thank you again for your help.
    Moistcabbage, Ranger and Basscat are amazing people.
    Im gonna definitely dedicate time to learning more about fixing the car and stick around to try and help as much as I can throughout the years.
  2. #122
    Jul 2013
    26
    105
    So after an hour and a half of waiting, the engine was cooled down, coolant was sitting at 115. It says check my levels, I did, I added some in very slowly, started it up, and watched the temp rise to about 224-227 after a good minute of 3K RPM to purge.
    I was excited to see it stopping at 227 and offered to go pick up my sister from the bart, I had 10 minutes to kill, so I hit a straight away and floored it to see what kind of power I am dealing with. (probably 4 seconds)
    SHortly afterwards it jumped up to about 235-240.... then a couple minutes more of driving towards the bart (subway system), It hit 250..255...Hey... your coolant is hot as hell! Idle engine!
    This is the rise I was worried about. I am thinking the hollow bolt purge line got clogged, again, maybe, somehow? And I will bleed it out through there in the morning when everything is super cooled off.
    Edit:
    The radiator hoses were super hot, and suuuuuuuuper puffy and hard to squeeze, which I didn't put much effort into squeezing something overheating..
  3. #123
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Not sure if its been suggested but has it been block tested?
  5. #124
    Jul 2013
    26
    105
    How much does it cost, if any? Where should I go/do/have?
    Thank you in advance!
  6. #125
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    AutoZone has a block test kit through their loan a tool program. All you actually have to buy is the test liquid.
    Easy to do yourself, preferably after an overheat. There are a couple of videos on youtube on how to do it, one good one by a member here.
  7. #126
    Jul 2013
    26
    105
    Easy to do yourself, preferably after an overheat. There are a couple if videos on youtube on how to do it, one good one by a member here.
    Wow this test makes me really nervous.
  8. #127
    Sep 2010
    East Boston MA.
    29
    26,323
    Performing the test, or the possible result?
  9. #128
    Jul 2013
    26
    105
    Ah man. What it is is my mix is way the **** off. Nooooooooooo doubt in my mind. I'm gonna have to start over.
    According to: EETC orp, an Antifreeze Company
    "Furthermore, more often than not the final engine coolant (antifreeze/water) mix is not within the recommended range, dramatically shortening engine and cooling system life."
    I'm starting to think I should buy into this 50/50 Mix deal. Just get a couple jugs of that, drain the radiator out of the lower radiator pipe, this time if I can get the bottom one, that's where I'm aiming.
    Is it possible to somehow safely drain out the car with that method while pushing some out via acceleration and I can go the 'high priced water' coolant mix level, at least then I'll know I won't be at a 20/80 or a 30/70.
    Edit: By safely drain, I mean take it to empty empty empty.
    The result.
  10. #129
    Sep 2010
    East Boston MA.
    29
    26,323
    The mix isn't THAT critical. Somewhere around 50/50 is fine.
    You can't drain the entire system, at least not without removing the crossover manifold. There's no hose or drain low enough in the system to get all of the coolant out of the block. You need to add slightly more coolant than water, that's all.
  11. #130
    Jul 2013
    26
    105
    Exactly, somewhere around 50/50 is what I'd get with pre mix. I just simply don't trust myself to do a mix. I might have to take it somewhere for sure and see if I can't find out how it's done. I'm a visual learner.
  12. #131
    Sep 2010
    East Boston MA.
    29
    26,323
    I thought you had added straight water to the system?
    If so, adding 50/50% to what's left in the block will end up being less than 50% coolant. Mix 3/4 of a gallon of distilled water to 1 gallon of full strength coolant to make up the difference.
  13. #132
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    1) pull the rad drain plug, reseat it
    2) Use this: http://www.autozone.com/autozone/acc...er=672816_0_0_
    This isn't that difficult.
  14. #133
    69
    82,269
    Quote Originally Posted by rkeating09 View Post
    This is NOT a good sign. Definitely do the block test after an overheat episode and do not top off the coolant before hand. Be prepared for bad news. This doesn't look good.
  15. #134
    Jul 2013
    26
    105
    I hate my life. :|
    So, after this discovery, I am assuming that the hollowbolt is the culprit.
    I undid the tube, cleared the hollowbolt and the hose (as best as I could on the hose).
    Previous Purge line results:
    Bubble formation for a while, turned into a stream.
    This Purge line:
    Nothing. Not even a little. (Leak? Blockage? Whats broken)
    It is telling me once again to check my coolant level. Could I just not have enough in the system?
  16. #135
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Low coolant message=add coolant.
  17. Remove Advertisements
