New to Cars in General, have a 95 Eldorado, plethora of problems - Page 10
Page 10 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 136 to 150 of 256
Like Tree42Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, New to Cars in General, have a 95 Eldorado, plethora of problems in Past Cadillac Vehicle Discussion; Originally Posted by stoveguyy Low coolant message=add coolant. Correct, however I am so not aware of what mix is in ...
  1. #136
    rkeating09 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Jul 2013
    26
    105
    Re: New to Cars in General, have a 95 Eldorado, plethora of problems, help?! D:
    Quote Originally Posted by stoveguyy View Post
    Correct, however I am so not aware of what mix is in there currently.
    I've been running straight water (see first post), I drained it out yesterday, was pretty murky with coolant in there as well.
    After draining it out yesterday, I tried to follow some instructions stating: "Put 1 1/2 Gallon of Antifreeze after draining, and top off with water."
    I got 3/4 of the first thing of coolant before it became a bad idea, mostly because I'm dumb and did it with a warm engine. It filled to the top and didn't continue emptying into the system, so I drained it out again, ran water until it came out clear.
    I then premixed a jug of coolant to a good 50/50, if anything 45(w)/55(c) and added it until the message went away.
    That's when I took it out for a spin, floored it for a couple seconds, and then got massive overheating.
    I checked the purge line this morning, nothing was coming out. Coolant level is low.
  2. #137
    69
    82,286
    Coolant/water ratio is irrelevant at this point. It will not cause the engine to overheat or use coolant. I am more concerned with your "suuuuuuuuper puffy and hard to squeeze" hose. Get that purge line to flow. Rod out the hollow bolt and blow through the rest of the line. If it's clogged, clear it. Then if you still overheat, do the block test.
  3. #138
    Jul 2013
    26
    105
    I took a wire hanger to it this morning. In as far and as much as I could go, nothin, even after started the engine with the tube off to see if it would flow. I put coolant in recently, felt the hose but it was probably the engine vibration I felt. I will check the hollow bolt again soon.
    How far in can / should I go with a wire hanger in the hollow bolt?
    Which 'line' and blow through it with what?
    And thank you for reviving my hope for this car.
  5. #139
    69
    82,286
    Quote Originally Posted by rkeating09 View Post
    The line you remove from the hollow bolt that runs to the surge tank. Just give it a blow job. You should be able to blow through it easily, just like a straw.
  6. #140
    Jul 2013
    26
    105
    I'm generally gullible, but I think I am going to go out on a limb here and just ask:
    You want me to put my mouth on the hose, and blow? Disregard coolant on or around it?
  7. #141
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Well don't swallow any coolant, but yes.
  8. #142
    Jul 2013
    26
    105
    What about you know, a bike pump?
    I will just blow into it.. Haha
    Took the hose off, and blew it to try and please it to kicking into shape and working:
    Cannot blow through it, clogged?
  9. #143
    Sep 2010
    East Boston MA.
    29
    26,323
    Definitely clogged.
  10. #144
    Jul 2013
    26
    105
    Definitely clogged.
    And what do I do about it?
  11. #145
    Sep 2010
    East Boston MA.
    29
    26,323
    Did you remove the hose from the hollow bolt and rod it (the bolt) out?
  12. #146
    Jul 2013
    26
    105
    The hollowbolt that I poked through the first time, or the other end of the hose?
    When I 'rodded' (which I am assuming means to push a wire hanger through) the hollowbolt the first time, daaaaays back. I got bubbling / falling into a stream.
    When I did it this morning, nothing came out of the hollowbolt, and nothing came out of the hose (except initially some black liquid residue came out, not a lot). No bubbling, no stream, nothin. Even when I ran the car.
  13. #147
    Sep 2010
    East Boston MA.
    29
    26,323
    Just to clarify, did you disconnect the hose at the surge tankand blow, or you disconnect the hose at the bolt and blow?
  14. #148
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    I bet OP is a troll. Just trying to sound stupid. And it's working
  15. #149
    69
    82,286
    Why is this so hard? Hollow bolt is rodded out. The line is clogged. Clear it with compressed air or a long piece of 12 gauge wire. Put it back together and let the engine purge itself. This is not rocket science. It should not take 10 pages to accomplish this and be able to move on.
  16. #150
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Ditto
  17. Remove Advertisements
