Possible cracked plenum?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Possible cracked plenum? in Past Cadillac Vehicle Discussion; Ok so yesterday it stalled out in traffic and ran really rough so I pulled codes P0300 engine misfire even ...
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    27
    2,337
    Ok so yesterday it stalled out in traffic and ran really rough so I pulled codes P0300 engine misfire even read up and used a scan tool but it wouldnt give me the exact cylinders So I pulled the spark plugs
    And found this also
    Between the corroded contacts and old plugs I figured that was it..... After I put in the new plugs it ran/drove fine for a few minutes but after that it went back to the P0300 ( I did the hold screw driver to each injector to your ear test and got a clickclickclick from each one) what I'm thinking is the new plugs burnt the extra fuel/air a cracked plenum would let in then couldn't keep up again?...... Also I have a burning plastic smell when the engine gets up to temp and starts stalling
    Any suggestions?
    68
    81,891
    Re: Possible cracked plenum?
    A ripped plenum duct would set a P0171 & P0174 code.
    Change the plugs and clean the contacts.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    The OP stated he DID change the plugs...Are the coil packs swappable on these? Can't rememeber if they are or not. I would take the car to a local parts store and have them scan it, hopefully their scanner can pick up which cylinder is misfring. Once you figure out which one it is you can narrow down your culprit.
    If the coil packs are swappable I would swap them to see if the miss follows the coil pack or not...
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,356
    FIRST - can we correctly assume
    you used the correct ACDelco plugs -
    cleaned and inspected all the boots -
    cleaned the terminals on the coil cassettes -
    there are TOO many things it COULD be to list -
    what would make diagnosing the problem much easier -
    is to narrow down the cylinders to the one misfiring -
    try this -
    engine running - in gear - feather the throttle
    to INCREASE the effects of the misfire -
    what we are trying to do - is AGGRAVATE the misfire -
    so it will finally set off a flashing SES light -
    at that point - the code for the specific cylinder misfiring should have set -
    P0301 - P0302 - P0303 - etc -
    I suspect a faulty coil cassette - but which one?
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    27
    2,337
    I tried a scanner at oreilys and that thing couldn't tell anymore than the built in.... I'll try autozone later..... I did call a local wrecking yard 65$ for a tested pack ( cause I remember reading sub said they're pretty reliable to begin with so just get a used one) the plugs needed replaced regardless.... If it is the packs I sure hope its the front damn annoying air pump in the back
    Edit: of course only 41-987 and I will try that thanks basscatt
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    I installed used coil cassettes in my 2001 with no issues at all...no way was I spending what the dealer wanted for a new one...The front one is just as easy as changing a wiper blade, but yes, that rear one can be a PITA...We need to find out which cylinder is misfiring before we can go further though.
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    27
    2,337
    Agreed 2468 is front and 1357 is back correct?
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    Quote Originally Posted by cadi509 View Post
    Correct.
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    27
    2,337
    Went to autozone same thing will not show the cylinder misfire just p0300 I also heard the belt squealing when I was there trying to bring the flashing ses light up by reving in drive which it has never done before
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Weird didnt you just replace the tensioner for that belt the day we did my brakes or was that just the one for the water pump assembly?
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    27
    2,337
    Yep both belts and wp tensioner.... Going down to get a used pack right now we'll see
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    27
    2,337
    New(used) coil pack all good to go even lucked out with it being the front too!
    68
    81,891
    Quote Originally Posted by curtc View Post
    Yes they are. The only difference is the color.
  16. #14
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    Thanks Ranger, now I remember actually...The one I used for the front was black because I couldn't find a silver one to match the original one in my area...
    And to the OP...Good to hear the coil fixed the issue! Got to love those cheap and easy fixes
  17. #15
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    27
    2,337
    Now occasionally the ses light will come on and I get a p0410 secondary air pump code.... It doesn't affect driving since its not cold out and the cat lights easy enough..... But why would this code come up all of the sudden would it be because I disconnected the air pump on the rear cassette pack when I did the spark plugs?
  18. Remove Advertisements
