01 ETC changing the coolant procedure and recommendations
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 01 ETC changing the coolant procedure and recommendations in Past Cadillac Vehicle Discussion; Guys my ETC has only 39k miles, most of the miles have occurred only over the past 18 months the ...
    robski is offline Cadillac Owners Member
    Automobile(s): 2001 ETC
    Jul 2013
    Dallas
    8
    Guys my ETC has only 39k miles, most of the miles have occurred only over the past 18 months the wife went back to work, other wise the car only first saw rain only a few times!. New on the site and I have decided to change the coolant. All though I wrench and build classic muscle and pro-touring cars, I have never touched this car. What is the best procedure, drains, do you recommend a flush? What modern coolant is the best? Never been changed it ,car runs great just think it's time.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Re: 01 ETC changing the coolant procedure and recommendations
    Drain it via the petcock on the driver side of the radiator, drop the splash shield. Refill with whatever came out, if it's orange, refill with Dex-cool 50/50. No need to flush.
    68
    81,922
    FYI, you will not get all the coolant out of the system. When you refill it, rev the engine to 3K and hold it for a minute to purge the air. Top it off and cap it up. Check the level again after the next drive or two (after cool down). Top off as necessary.
    Jul 2013
    Dallas
    8
    Thanks I will get it done this weekend, wife came home from work today and mentioned the temp gauge moved sightly from the norm-in the middle to just a very little bit to the right-warmer side. Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    robski - You mean the temp gauge actually MOVED ??? Horrors !!!
    You need to read the cooling and temp gauge stickys in the Engines: Northstar Performance forum as well as the entire Cadillac Technical Archive way up ^^^ in the black bar.
    Why ? To learn why, when, and how the cooling fans work, the temp gauge actually moves, and what the actual symptoms of real cooling system problems are.
    In your car it is perfectly normal, in warm/hot weather, to see the temp gauge needle move to almost the first tick past 12 o'clock.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
  9. Remove Advertisements
