98 Eldorado Green Coolant Being Used Stay or Switch
Closed Thread
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 98 Eldorado Green Coolant Being Used Stay or Switch in Past Cadillac Vehicle Discussion; I just picked up my 98 Eldo last nite and I noticed it needs a radiator. Doesnt over heat just ...
    fivepointohman is offline Cadillac Owners Member
    Automobile(s): 98 Eldorado ( previously 96 SLS )
    Jul 2013
    36
    44
    I just picked up my 98 Eldo last nite and I noticed it needs a radiator. Doesnt over heat just leaks out the sides, it was leaking Green Coolant which I was shocked it wasnt dex since the previous owner was a stickler with maintence... I have heard the stories of Green being better than dex for the Head gaskets... So my ? is what should I do, add Dex or stay with the Green.... It has 133K and runs excellent and I want to keep it that way.
    Quick reply to this message Reply
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    Re: 98 Eldorado Green Coolant Being Used Stay or Switch
    I do not know what you should do.
    Me?
    I would stick with the green.
    Submariner409's Avatar
    Submariner409 is online now If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,621
    Whatever floats your boat. They're both excellent coolants - but I would change either at 3 years - religiously.
    If you DO change from one to the other, an extended fresh water (garden hose) flush is in order - the two do NOT like to mix.
    That said, Prestone now markets a yellow long-life coolant that will mix with any coolant out there ----. Not orange-ish like DEX-COOL - Yellow.
    Caddydrummer67's Avatar
    Caddydrummer67 is offline Cadillac Owners Fanatic
    Automobile(s): '02 ETC 32,000 miles 2002 F55 STS 78,000 miles
    Jun 2012
    Black Hills of SD
    240
    I think it is about personal preference, although I've also heard the new green AF is better.
    More important is that you change it out about every two years at most.
    I'd stick with what's in it.
    69
    82,188
    Quote Originally Posted by fivepointohman View Post
    Internet myths. Either one will serve it's intended purpose quite well.
  8. Remove Advertisements
Closed Thread
