antenna repair
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, antenna repair in Past Cadillac Vehicle Discussion; A while back I read a post about repairing a power antenna. It described using the plastic line from a ...
    philthy's Avatar
    philthy is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2004
    47
    46
    antenna repair
    A while back I read a post about repairing a power antenna. It described using the plastic line from a string trimmer to replace the nylon cable inside the antenna motor that raises and lowers the antenna mast. The cable in mine is broken and I want to make the same repair, but can not find the post. I tried searches using all kinds of different keywords with no luck. I am 99.9% sure it was on this forum board. Can anyone help?
    68
    81,914
    Re: antenna repair
    I remember the post but don't remember where it was. I just fixed mine a few months ago. I got the kit from http://www.antennamastsrus.com for $50. Other have said that the dealers have the kit for $15. I called every GM dealer in the area to no avail. Check around before you call anntenamastrus. THe instructions in the kit are right out of the factory service manual. Follow them to the tee.
    91TexasSeville's Avatar
    91TexasSeville is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX-V8, 1991 Eldorado
    Oct 2004
    Near Houston
    66
    1,543
    Re: antenna repair
    Quote Originally Posted by philthy
    Ranger is right!
    Every OEM repair kit that I have seen is $49.95 USD for the mast and cable assembly. I purchased a GM refurbished antenna from eBay for $60. No real savings other than, I now have a spare antenna to repair. Be careful with aftermarket power antenna's, most do not have the same antenna lead adapter as the Cadillac (RCA Female or RCA Male). Most aftermarket antenna utilize a nutted adapter similar to a cable televison connector.
    If you happen to find a Cadillac antenna in a salvage yard in the lowered position, meaning fully retracted, it may still be good, but for how long? Fishing line, or monofilament string trimmer will not work for long, read below.
    On my Seville, I took the antenna apart to find that the monofilament cable had separated from the metal anchor which connects to the spool. I used a heat gun to bend the monofilament cable to the same shape as the metal anchor then reassembled. It worked great until we had a light frost. The monofilament cable broke again at the spool leaving the antenna half raised. That was the time I started looking for the OEM repair kit or another antenna.
    The FSM (Factory Service Manual) provides step by step instructions for disassembly and repair of the power antenna mast assembly.
    montano's Avatar
    montano is offline Cadillac Owners Member
    Jan 2004
    ARIZONA
    56
    10
    Ur7x is offline Cadillac Owners Connoisseur
    Automobile(s): 02 STS
    Dec 2004
    1,262
    Re: antenna repair
    GM Direct even cheaper...
    Page 1: 1-1 of 1 items
    GM PART # 22038184
    CATEGORY: All
    PACK QTY: 1CORE CHARGE: $0.00
    GM LIST: $15.50
    OUR PRICE: $7.75DESCRIPTION: CABLE
    NOTE: GMPartsDirect.com carries 380,000 GM parts. Due to the number of parts available, the part you are searching for may not appear in these results. Please use our Customer Service page if you need help locating a GM part. Can’t find a part?^ Back to Top ^
    68
    81,914
    Re: antenna repair
    Quote Originally Posted by Ur7x
    GM PART # 22038184
    CATEGORY: All
    GM LIST: $15.50
    Boy, did I get screwed! I guess I should have done a little more research.
    Silverio is offline Cadillac Owners Member
    Automobile(s): 78 Eldorado
    Nov 2012
    Re: antenna repair
    I also read to use clothesline with the metal wire inside. Removing the previous material up inside the antenna, gluing in the wire reinforced clothesline with JB Weld. Eventually attaching the other end as described in other posts. Note: if the hole to pass through is too tight, simply drill it out so new line easily passes through. Add some grease to ensure smooth operation.
  10. Remove Advertisements
