Charging system problems, need opinions
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, Charging system problems, need opinions in Past Cadillac Vehicle Discussion; Greets, Some rain today, first trip no problem, second trip the same. Third trip...first I get a message saying the ...
    DJSG3 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Deville DTS
    Dec 2005
    Joisey
    254
    Greets,
    Some rain today, first trip no problem, second trip the same. Third trip...first I get a message saying the charging system is too high, followed by the abs & traction lights coming on followed by the the gear indicator lights flashing followed by the message battery not charging. Turned it off, turned it back on and no problem. Put it in gear and same problem first its up around 16volts then back to down to 12, turn anything on and it drops lower. Codes set were PCM P0563, IPC B1911 B1982 U1255, ACM B1982, TCS C1237 & PZM B1982. All of them refer to high voltage problems with the exception of two of the IPC codes - U1255 (Class 2 Init error) & B1911 (Generator L-Terminal problem). At this point it seems to have stopped over charging but is not charging at all. So do I need a new generator/alternator or does it sound more like a ground/short issue?
    DJSG3
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: Charging system problems, need opinions
    Generator L terminal problem. Did you look at the alternator terminals? Are they secure? 16 volts can damage other controls so fix it right away. If you cannt, then have it towed to a shop.
    Dec 2005
    Joisey
    254
    Oh I am trying to fix it, but getting that gen/alt out of the car is a real head scratcher. Service manual says all I need to do is loosen the rear bracket (hah) and roatate the alt. to get it out. Let me tell you right now that is a fairy tale. What needs to be done apparently is remove the radiator and the fans.... just to get a frickin alternator out. Worst car I've ever owned hands down up or sideways.
    DJSG3
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Quote Originally Posted by DJSG3 View Post
    DJSG3
    Remove the fans then it'll be much easier. No need to remove the radiator
    Dec 2005
    Joisey
    254
    Removed the fans and still no go, had to remove the rad and don'tcha know my particular vehicle doesn't have oil cooler lines but a second rad just for that purpose tucked behind the first rad so had to seperate them to get the 1st rad out once it was out had to slide the alt along the bottom from left to right side to get it out over by where the air filter sits (pain in the butt to say the least) About the only positive thing in all this is all the bolts came out easily, no breaks no strips...course I still have to put it all back together again (whee)
    DJSG3
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The front "radiator" is the A/C condenser, the thicker one behind it is the radiator.
    Dec 2005
    Joisey
    254
    I know about the condenser, but on my car there is another one in there. Possibly someone modified it? I could tell while taking it apart I wasn't the first person in there, so who knows. Anyways that female dog is out and in the end thats all the counts. (still F'ing hate working on this car tho)
    DJSG3
    Sep 2010
    East Boston MA.
    29
    26,323
    Smaller radiator in front of the condenser? Power steering fluid cooler maybe?
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    I always did these from the bottom.
    Either way, no fun.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    I was fortunate enough to have my a/c compressor and the alternator go out at the same time in my Deville. Even with the a/c compressor removed, it was still a tight fit with just the front end supported with jackstands.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The alternator is supposed to come down the bottom. There is a small panel bolted on the subframe directly bellow the alternator. Removing the one fan is not helping much (other than seeing better what you need to remove) however since is so easy to remove why not.
    If you spin the alternator eventually you will find that one position is meant to come down that special opening.
    I am not sure but it seems I remember the top bolt is not suppose to be remove all the way (I mean there is not enough clearance). You unscrew it enough to release the alternator to drop a bit, then you can slide the bolt out.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    DJSG3
    You don't remove the Radiator, the Alternator comes out the bottom through the access panel:
    Removal
    1. Negative battery cable
    2. Serpentine belt.
    3. Upper front bolt.
    4. Raise vehicle.
    5. Front engine splash shield.
    6. Radiator support access panel.
    7. Loosen rear generator bracket from engine. Remove top bolt.
    8. Front lower bolt.
    9. Lower rear bolt.
    10. Upper rear bolt.
    11. Duct from back of generator.
    12. Electrical connections. Regulator, Battery output, Heated windshield (if equipped).
    13. Front generator/ A/C bracket.
    14. Rotate generator and remove.
    INSTALL OR CONNECT
    1. Generator to vehicle.
    2. Front generator/ A/C bracket.
    3. Electrical connections. Regulator, Battery output, Heated windshield (if equipped). Tighten
      • Output cable to 20 N.m (15 lb. ft.) .
    1. Duct to back of generator. Align duct to generator back duct.
    2. Upper rear bolt. Tighten
      • Upper rear mounting bolt to 47 N.m (35 lb. ft.) .
    1. Lower rear bolt. Tighten
      • Lower rear mounting bolt to 47 N.m (35 lb. ft.) .
    1. Front lower bolt. Tighten
      • Front mounting bolt to 47 N.m (35 lb. ft.) .
    1. Rear generator bracket bolt to engine. Top bolt was removed, Tighten
      • Bracket mounting bolt to 47 N.m (35 lb. ft.) .
    1. Upper front bolt.
    2. Radiator support access panel.
    3. Front engine splash shield.
    4. Lower vehicle.
    5. Tighten front upper generator bolt. Tighten
    1. Serpentine belt.
    2. Negative battery cable Tighten
  15. Remove Advertisements
