95 ETC Cooling Fan Issues
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 ETC Cooling Fan Issues in Past Cadillac Vehicle Discussion; So I bought the car a couple months back, 95 ETC with 177K. My current problem is the fans stay ...
    TimsEldorado is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Mar 2013
    35
    3
    So I bought the car a couple months back, 95 ETC with 177K. My current problem is the fans stay on long after the car has been off, I went outside and my radiator fans were mysteriously on when I hadn't driven the car in days. At any time I connect the battery the fans come on, have taken the battery out until I can figure it out... Recently the alternator and temperature sensor were replaced. Does anyone know how to fix this?
    I bought the car with a touchscreen, amp for the mids, (it had 4 12s, another battery and cap I decided not to buy with it.)HID headlights (which are horrible) remote start with alarm besides the factory.
    ran the codes and this is what it shows
    p052
    p109
    p137
    I032(current)
    No ACP
    No SIR
    No TCS
    s025
    s030
    s036
    s044
    s050
    s061
    s 070
    s071
    Any help?
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: 95 ETC issues
    Please post the definitions for those codes we don't have them all memorized, and it being a 95 are OBD1
    Mar 2013
    35
    3
    Re: 95 ETC issues
    p052 pcm memory reset
    p109 keep alive memory reset/ pcm has lost primary battery power
    p137 loss of traction control system data
    I032 loss of abs / tcs data (current)
    S025 right rear damper solenoid valve short to b+
    S030 speed sensitive steering fault
    S036 Electronic level control compressor short to b+
    S044 lift or dive signal fault
    S050 road sensing suspension modular fault
    S061 right front position sensor fault
    S070 left front accelerometer fault
    S071 Right front accelerometer fault
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,569
    Re: 95 ETC issues
    Quote Originally Posted by TimsEldorado View Post
    p052
    p109
    p137
    I032(current)
    No ACP
    No SIR
    No TCS
    s025
    s030
    s036
    s044
    s050
    s061
    s 070
    s071
    Any help?
    that could be as simple as a defective fan relay -
    if the PO didn't hack up the wiring -
    you should be able to unplug/remove the mickeymouse HIDs -
    and install a good set of halogens -
    for the rest - I would start by clearing all the codes -
    drive the car - and see what comes back -
    69
    82,180
    Re: 95 ETC issues
    I agree with Bass. Check (and hope) for a possible stuck relay.
    Mar 2013
    35
    3
    Re: 95 ETC issues
    Can anyone snap a quick picture of the relays for me?
    I disconnected all the audio extras and will rewire it without amps and such, took out the HIDs which weren't even a matching set.
    Going to take out the aftermarket alarm. Just trying to take out all the crap to hopefully mitigate the potential problems.
  9. Remove Advertisements
