99 STS - end of the road?
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 STS - end of the road? in Past Cadillac Vehicle Discussion; Just recently I getting all the classic Northstar signs of the headgasket letting go, random temperature rise, occasionally near the ...
    curlywurly is offline Cadillac Owners Fanatic
    Automobile(s): 1999 STS & 1992 STS
    Jun 2011
    OKC
    118
    Just recently I getting all the classic Northstar signs of the headgasket letting go, random temperature rise, occasionally near the red mark (enough that the A/C was shutdown), seems to happens when the car is under more load, coolant disappearing now and again, and I think I can small exhaust fumes in the surge tank, and...the block test came back positive, the blue dye turn very slightly green.
    The car has done 179,000 miles, but it still drives very well, but if driven hard in the hot OK weather (100F outside) the temp will rise to the 2nd marker pass middle pretty much every time now, didn't do this few months back.
    The odd thing, and I'm curious, I bought the car with about 3 years ago with 142,000 miles on it, from friend, and it has always had a slight oil drip/leak (he gave full disclosure on this fact)and told me it needs a quart of oil about once a month to top it up, and sure enough that what I've been doing, but, since this possible head gasket issue started (around 3 weeks now) the oil leak/drip has completely stopped...why would this be?
    I'm coming to the conclusion that it might be the end of the road for my caddy, at that mileage, and my location, (nobody near me does the head gasket repair/mod) it doesn't seem to make much sense in having the expensive repair done, the car also has minor hail damage, but other than that, and the head issue, the car is in good shape.
    Year 2009 - 2010 - Replaced air suspension compressor and filter
    Year 2011 (approx mileage 152k) - Replaced rear right passenger door power window motor/lifter unit
    Year 2012 (approx mileage 158k) - Replaced coil packs, plug wires, air filter, idle air control valve, MAP sensor, TPS
    Year 2013 (approx mileage 170k) - Replaced surge tank, surge tank cap, radiator, top and bottom radiator hoses, rear struts, front & rear brake pads, 2 HVAC vent actuators, small power steering hose
    Always had Castrol Full Synthetic 10/30 and filter change when indicated by oil life monitor.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Another 99 ...
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Re: 99 STS - end of the road?
    Sorry to hear that. We love ours. I have a '99 too, same color. It IS a shame that repair costs can make these unusable before their time.
    What's it worth like that? I would love a dead STS for a parts donor.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    how far from okc to wichita?
    EcSTSatic's Avatar
    Dec 2004
    Wichita, KS
    5,212
    Quote Originally Posted by stoveguyy View Post
    180 miles tops.
    Jun 2011
    OKC
    118
    I'm fairly sure it could make 180 miles at a steady cruise - why do you ask?
    I'm still curious as to why the oil drip/leak stopped....it has plenty of oil BTW
    bdk4444 is offline Cadillac Owners Member
    Jun 2013
    17
    My 2000 Seville was having temp spikes and the belt / pully to the water pump had gone bad. It is on the right side of the engine on top (visible without removing anything under a black guard). It might not be as bad as you think.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Many water pump drive system pictures in my albums. Community tab, Albums, the red Seville.
    Problem is, the OP's cylinder block exhaust gas test showed positive for exhaust gas components in the airspace over the coolant in the surge tank.
  11. Remove Advertisements
