Replacing CKP sensors
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Replacing CKP sensors in Past Cadillac Vehicle Discussion; Good evening, I have a 2002 Eldorado which stalls as soon as I start it if I don't hold my ...
    Bewos624 is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado ECS,1991 Eldorado Touring Coupe
    Jan 2011
    35
    7
    Good evening, I have a 2002 Eldorado which stalls as soon as I start it if I don't hold my foot on the gas peddle. Back in May this happened but the alternator went bad at the same time so once I got the car back on the road I thought that was the problem. 2 weeks ago it left me in a parking lot stalling as soon as I took my foot of the gas. I checked for codes but there wasn't anything.
    to make a long story short, I decided to replace the sensors since I read on the forum about the 2000- 2004 Northstars with defective sensors ( one black and one tan). So I ordered the new sensors ACdelco 12575481 (grey) and AcDelco 12575482 ( black) and decided to replace them this evening. When I got to the old sensors they were the same ones. Does it make sense that the sensors are bad or is it more likely there is another issue that is causing the stalling.
    Thanks for your help,
    Steve
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Your symptoms aren't caused by failing CKPs. When was the TB last cleaned?
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    Could be different things, like egr not working properly, vacuum leak, a ground problem, etc. I changed the ckp sensors on my 96 and it cured things, but there was a random misfire code and the tach didn't work either. Also had to re wire everything... I'd say since you already have them go ahead. There are a couple of threads here pointing out which goes where... Good luck!
    Sep 2010
    East Boston MA.
    29
    26,325
    http://www.cadillacforums.com/forums...rol-valve.html
    Don't neglect the perimeter of the throttle plate.
    Jan 2011
    35
    7
    Re: Replacing CKP sensors
    Thanks guys . I cleaned the throttle body at ~ 95K when i did the Plenum gasket ( I am currently at 104K).
    Thanks for the suggestions I guess I will just replace the sensors since I have them and investigate a few of these other things.
    Thanks again,
    Steve
    MoistCabbage ,
    thanks for that link I didn't clean the IAC when I did the throttle body so Ill give that a try tomorrow.
  8. Remove Advertisements
