OIL - I am old and ignorant, so please help me make sure of something.
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, OIL - I am old and ignorant, so please help me make sure of something. in Past Cadillac Vehicle Discussion; As I have read and tried to understand the different arguments in older threads and the technical archives about oil ...
    SissyBoyFloyd's Avatar
    SissyBoyFloyd is offline Cadillac Owners Member
    Automobile(s): 99 Eldorado ETC
    Jun 2013
    North of San Diego
    68
    50
    As I have read and tried to understand the different arguments in older threads and the technical archives about oil changes for the Northstar engine in the '99 Eldorado ETC, I want to make sure I understand it correctly.
    I take it that there is no need to change your oil before the info center tells you to, and that using synthetic oil is an absolute waste of money. Also, that it is natural for the engine to use oil and for you to have to add a fresh quart every so often in between oil changes. Now do I have that all correct? Or am I missing anything? I also assume one should change the oil filter at each oil change, or am I wrong on this one?
    PS. Since I just bought the car and don't know when the oil was changed last, should I just trust the current reading of the info display which says 85% still.
    Thx all.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Re: OIL - I am old and ignorant, so please help me make sure of something.
    No need for synthetic, stick to what your manual and oil cap tell you. i change my oil every 3 months, regardless if i drive it everyday or not. And as a rule of thumb i change oil and coolant when getting a used vehicle, i'm picky like that.
    68
    81,938
    You are correct on all counts Floyd.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Stick with the manual specs and OLM periods. I would not change it any sooner. Synthetic might save some gas, but unless you ignore the OLM and extend the oil change periods, that savings is used up in the extra cost of synthetic. That's my $.02. Basically, you have it correct.
    The PO might have reset the OLM to make it look like it was changed recently. It should look pretty clean at 85%. If it is, I would consider it accurate.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by SissyBoyFloyd
    You are 100% correct on all points.
    A note on the OLM, replace the oil when it reaches 0%, but no longer than 12 months.
    I would definitely change it.
    Your engine uses 10W-30, 7.5 quarts with an oil and filter change. Correct level on the dipstick is half way up the hashmarks (xxxxxXxxxxx).
    Quote Originally Posted by EcSTSatic
    Using synthetic makes absolutely zero difference in gas mileage.
    dou1t2 is offline Cadillac Owners Member
    Automobile(s): 96 Seville SLS and 99 Eldorado ESC,also 91 F-150 and a 73 MG
    Aug 2010
    NE Orygun
    60
    80
    I'm with vincentm on changing oil when buying a used vehicle. I suppose that someone could reset the oil life setting without actually changing the oil, thus misleading someone, although the oil when checked would be darker than a recent oil change would appear. my 2 sense!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,374
    Quote Originally Posted by SissyBoyFloyd View Post
    Thx all.
    I agree with Ranger - and MC -
    you are 100% CORRECT on all points -
    however - if you don't put many miles on the car -
    change the oil once a year -
  10. Remove Advertisements
