On a 1994 Seville SLS , does anyone know where the Maxi fuse panel location is. Where the big fuses and breakers are. Also does anyone know where I could find the ABS valve relay?
Before you get too far into your ABS system, a word of caution. If you have recently replaced calaipers or in any way reduced fluid line pressure, the ABS trouble light will appear due to air trapped in the system. Another probable cause is a faulty sensor or contaminated sensor connection.
Investigate the sensors first through your system diagnostics.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
