1993 Eldorado Touring Coupe Antenna
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1993 Eldorado Touring Coupe Antenna in Past Cadillac Vehicle Discussion; Hello all, I'm a first time user looking for some help with an antenna issue. The motor works fine. There ...
    rogman is offline Cadillac Owners Member
    Jul 2013
    1
    Hello all,
    I'm a first time user looking for some help with an antenna issue. The motor works fine. There is a small nylon cord that seems to be unattached? How do I hook it back up?
    68
    81,927
    Re: 1993 el dorado touring coupe
    You don't reattach it. The cable is broken. You replace it. If you can't find the repair kit at a dealer, check www.antennamastsrus.com. Follow the directions to a T.
    P.S.
    There is a very good tutorial in the Tech Tips section.
    P.P.S.
    I edited your title to be more descriptive.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    2manyhotrods's Avatar
    2manyhotrods is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ETC coupe.
    Jun 2013
    Massachusetts
    438
    I cheated a bit on the repair to my '99 ETC power antenna.
    Went to Holland's Used Auto Parts yesterday and pulled a unit from a dead '99 SDV.
    Took it home and my wife and I removed the ETC's antenna and in less than an hour had Hollands $25 deal installed and operating.
    Toughest part of the job is needing 2 pairs of hands and a couple of small thin blade screwdrivers to pop the clips in the connectors without braking them.
    Screw overhauling the old piece of rubbish!
    68
    81,927
    Re: 1993 Eldorado Touring Coupe Antenna
    You can always take your chances with a junkyard unit. Just keep in mind that it too is 15-20 years old.
    Jun 2013
    Massachusetts
    438
    Holland's guarantees the antenna for 30 days. That enough time to run it up and down numerous times.
    If 1 month doesn't kill it then I'm ahead by saved money.
  9. Remove Advertisements
