95 Eldorado coolant crossover/ water pump housing help
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 Eldorado coolant crossover/ water pump housing help in Past Cadillac Vehicle Discussion; The gaskets on the coolant crossover were leaking so I am ready to install new ones, but..... What are the ...
    beech1cm is offline Cadillac Owners Member
    Automobile(s): Eldorado, coupe deville
    Jul 2013
    5
    What are the torque for the 8 bolts and what do I use on the threads for the bottom 4 bolts?
    Thanks
    X-Hibition is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Eldordo ETC Collector's Edition with Aux Input
    Aug 2011
    Outside Boise, ID
    100
    Re: 95 Eldorado coolant crossover/ water pump housing help
    Install the water crossover on the engine. Tighten
    Tighten the water crossover bolts to 25 N·m (18 lb ft).
    Install the water pump cover. Tighten
    Tighten the water pump cover to 10 N·m (89 lb in).
    Notice
    Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    Looks like the bolts all go in dry.
    At least that's what it says in my Electronic Service Information Software 1980-2005 DVD that I got on e-bay...
    Jul 2013
    5
    Thanks for the information. The bottom four holes do go through to the waterjacket in the block, and have an orange colored substance on those four bolts. I am going to attempt to ask at a local dealership to see if anyone there is willing to help.
    Thanks again!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Thread sealant, I used this:
    http://www.permatex.com/products/pro...sealant-detail
    Good luck getting a torque wrench on those lower bolts. Remember, you can't use any universal joints or wobble extensions.
  7. Remove Advertisements
