Results 1 to 12 of 12
Thread: 1997 seville ac compressor switch (where?)
    danalex is offline Cadillac Owners Member
    Automobile(s): 1997 seville sls
    Dec 2008
    57
    257,700 miles. Changed the heater core over the weekend. Pretty sure I reconnected everything.
    Now I got the "low refrigerant" "ac compressor off" error on the dash computer. Can't add Freon since the compressor won't come on.
    Ran code checker...only one code (evap related...been there for over 100K miles); cleared it (again).
    No codes now.
    Computer shows compressor still OFF.
    Unplugged what I believe is the ac compressor switch (along the ac tube going towards the fire-wall). Put a paper-clip across the "male" sensor tips--the compressor still not kicking in. (haven't tried to insert paperclip into the "female" portion. ((NOTE: I'M NOT 100% SURE THAT'S THE PRESSURE SWITCH--IS IT?
    Believe a new/used compressor replacement and installation will cost more than KBB value. ((good car tho'...daily driver...70miles round-trip to/from work daily))
    Any help? Just want to get Freon back to correct level.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    You need to jump the harness, not the sensor itself.
    69
    82,273
    Re: 1997 seville ac compressor switch (where?)
    You should be able to enable the compressor by clearing the codes, but you need to have the refrigerant can hooked up, open and ready to go so that it draws in refrigerant before the low pressure switch trips again.
    http://www.gmpartsgiant.com/Page_Pro...049&SortKey=28
  5. #4
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    No ACM codes? I never needed to jump anything in these cars. Just clear the AC codes, not PCM. With that message, there should definitely be a code. When cleared, it should stay on long enough to charge.
    I forgot this part & I need to type faster. ^
  6. #5
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,694
    can WE assume you have evacuated the AC system -
    and it is sitting at 29" of vacuum - or close to it -
    OR it was - and you already put in 1 can of freon so far?
    follow both Ranger's and Aztech's advice -
    like Aztech - I never had to "jumper" the LOW pressure switch -
    to add freon - IF you follow Ranger's instructions -
    if you can't clear the AC code -
    try removing BOTH battery cables - and touch them together -
    that should clear all codes -
  7. #6
    Dec 2008
    57
    RESPONSE: I DON'T UNDERSTAND "JUMP THE HARNESS"
    RESPONSE: (A) Used a code reader to erase/clear the codes. (B) Can is hooked up; "lever" is squeezed (with Velcro-strap); can is connected to low-side. COMPRESSOR DID NOT KICK ON.
    quote:
    Clear the AC codes, not the PCM
    RESPONSE: Used a code reader to clear ALL the codes...code reader didn't give any AC codes (assume "AC" = air cond...but regardless, zero codes on the code reader)
    Regarding the system evac stuff....I'm not a/c savvy, so I haven't evac'd anything..
    To restate, the a/c was blowing gradually less cool air, until finally only have ambient air temp blowing. Got the low refrigerant on dash computer, plus "compressor off" on the dash computer.
    RANGER: THANKS FOR THE DIAGRAM--CONFIRMS I LOCATED THE COMPRESSOR CUT OFF SWITCH/CONNECTOR. NOT SURE HOW TO "JUMPER" THE SYSTEM TO GET THE COMPRESSOR TO COME ON THO'.
    quote: Remove both battery cables and touch them together...
    RESPONSE: REALLY??? ((I hate electricity...have wife with 911 on speed dial just in case when I tried to use the paper-clip across the sensor....)) If my code reader shows all the codes clear, wondering if that will clear anything else in order to get the compressor to kick on....?
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,694
    [QUOTE=danalex;10473073]quote:
    FIRST - your car has a built in code-reader -
    BETTER than the hand-held type -
    go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    when you replaced the heater core -
    did you disconnect the AC lines - and let the freon out?
  9. #8
    Dec 2008
    57
    Ref the "heater core" and "disconnect the AC lines"-- RESPONSE: No, didn't disconnect the AC lines..just the two hoses that run to the heater core.
    Ref the "built in code reader"--THANKS! FOUND THE ISSUE USING THE BUILT IN READER. (why'd I pay a hundred dollars for that handheld??? )
    Actually, I googled-to-death my issue; finally found a thread elsewhere (http://www.all-parts.com/repairs/Cadillac_Seville.html) and read it thoroughly to understand the on-board computer. After reading, then ran the onboard computer and found ACM codes--cleared them. ((didn't touch the others...I figure, hey, the car has run fine for 257K miles, why mess with codes...))
    After clearing the ACM codes, I exited the computer; turned the car on, and heard the A/C compressor click on!!!! I darted out to squeeze the Freon-trigger, and instantly felt the can go COLD as the system began to suck in Freon---YEAH!!! I had one of those extra-large cans, so I shook it and swiveled it until empty (over 10 mins). A/c lines are swetting and inside air is COLD again.
    THANKS TO ALL!!
  10. #9
    Feb 2012
    NYC
    50
    1,948
  11. #10
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    These cars have the built in code reader that does allot more than just reading/resetting codes (clearly better than a expensive aftermarket code reader).
    But yeah all you need to do is reset the low refrigerant code and the PCM will enable the compressor for a short time just enough to give you the chance to add refrigerant.
    However changing the heater core should have nothing (I mean really, really nothing) to do with the AC Compressor. You may have a leak and this is a coincidence (unless you knocked the lines and you made a leak in the process). Bottom line these things don't fix just by themselves, sooner or later the message will come back. I would use a die in the next charge.
  12. #11
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by N*Caddy View Post
    However changing the heater core should have nothing (I mean really, really nothing) to do with the AC (Evaporator)
    Yeah. Not in this car, anyway.
  13. #12
    69
    82,273
    Kind of figured that was your problem. It'll come in handy if you have other cars. Cadillac is the only one with it's own onboard diagnostics read out and clearing capability.
  • You may not post replies
