Charging Voltage
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Charging Voltage in Past Cadillac Vehicle Discussion; Hello everyone, I noticed today my 2002 Eldorado ETC wouldnt start, so I gave it a jump. It then started ...
    SamarthVader is offline Cadillac Owners Member
    Automobile(s): 1992 Seville, 2002 Eldorado ETC
    Nov 2011
    Worldwide
    25
    65
    Charging Voltage
    Hello everyone,
    I noticed today my 2002 Eldorado ETC wouldnt start, so I gave it a jump. It then started and ran fine. I noticed the voltage reading start at 13.0 when I started the car and rose to a steady 13.5 driving around. When I got my new battery a year ago I recall the charging voltage being 14.0 - 14.5 volts. Is my alternator going bad? What exactly is the normal range for charging voltage?
    Sep 2003
    Metro ATL
    4,854
    Re: Charging Voltage
    Quote Originally Posted by SamarthVader View Post
    ....What exactly is the normal range for charging voltage?
    Your normal is what you experience.
    There is no definitive answer to your question; too many variables involved in the charging process.
    Your battery has failed to crank the engine; that might be the only early warning you receive about battery condition. Battery condition is not related to battery age. As a starting point, have the battery load tested; worry about charging voltage later.
    Nov 2011
    Worldwide
    25
    65
    Thanks for the response. I also noticed the instant mpg reading is bouncing all over the place. Holding a steady 40 mph it jumps from 15 mpg to 50 mpg. Is this a related issue? It was working fine before the battery was discharged.
    Sep 2003
    Metro ATL
    4,854
    Focus, focus, focus.
    Load test the battery!!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    As posted, load test the battery - you can't start with damaged goods .............
    I have beat my keyboard to death trying to get across the fact that automotive lead-acid and "maintenance free" battery charging voltages are normally somewhat elevated above the nominal "12 volt battery" full-charge 12.6 volts.
    Read it from somewhere else - and the list of links is endless - Google and study wet cell battery and charging theory and learn something.
    http://www.landiss.com/battery.htm
    Nov 2011
    Worldwide
    25
    65
    How long should I wait after the battery is charged to test it?
    68
    81,926
    It doesn't matter on a load test.
  10. Remove Advertisements
