A/C problems/ B1324 code
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, A/C problems/ B1324 code in Past Cadillac Vehicle Discussion; I realize that there are millions of posts about A/C issues, but I haven't found anything that matches or even ...
    haucker20 is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Seville STS
    Mar 2013
    1
    I realize that there are millions of posts about A/C issues, but I haven't found anything that matches or even helps my situation. Here goes..... 2000 Seville STS that has a compressor that will not kick in. I have a trouble code on the dash of B1324, A/C overpressure. I have cleared the code and it immediately comes back on. I can jump the compressor in the fuse box by jumping the relay, and the compressor and clutch work awesome. The air inside is cold as ice, but when I take the jumper out and put the relay back in, the air gets warm as the clutch stops working. I have tested the low pressure switch. The switch itself ohms out at 1.26 ohms, and the connector has 5.18 volts. I have purchased a total of 32 oz of A/C Pro R134. When I first attached the gauge from the A/C pro, I got absolutely no pressure reading with compressor/clutch jumpered. I added a full 20 oz and got cold air on the passenger's side, but warm air on the driver's side. I then added approximately 8 oz of the 12 oz can. Again, with the clutch and compressor jumpered, I get ice cold air throughout the car. But I can't leave the relay jumped as it kills my battery. I am currently working on getting a set of manifold gauges to test the pressures. Any help that anyone can give me at this point??? Thank you in advance!!!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,681
    Re: A/C problems/ B1324 code
    Quote Originally Posted by haucker20 View Post
    the "problem" seems pretty basic -
    either you put too much freon in the system -
    and the high side pressure to too high -
    so to protect the system -
    the high pressure switch has disabled the compressor -
    OR - the high side pressure switch is defective -
    to diagnose the system - we need the following information -
    ambient temperature -
    with the AC set to 60* -
    fan set to medium speed -
    center vent selected -
    engine at a high idle - 1500rpm -
    high pressure reading -
    low pressure reading -
    discharge air temp at center vent -
    in the mean time - I would NOT recommend running the AC -
    with the safety switches by-passed -
    they are there for a reason -
    if you are looking to buy a manifold set -
    here is a great deal - for $60 - with shipping -
    http://www.amazon.com/Mountain-8205-...134a+gauge+set
    or $58.61 - on ebay -
    http://www.ebay.com/itm/Mountain-820...d5279a&vxp=mtr
