ABS codes?
Results 1 to 10 of 10
Cadillac Seville / Cadillac Eldorado Forum Discussion, ABS codes? in Past Cadillac Vehicle Discussion; So my ABS and Traction control light came on pulled the code it says B1227 left rear excess wheel speed ...
    97PearlEldorado is offline Cadillac Owners Member
    Automobile(s): 1997 Eldorado ETC
    Apr 2013
    Gaithersburg
    8
    ABS codes?
    So my ABS and Traction control light came on pulled the code it says B1227 left rear excess wheel speed variation? So would this just be a bad speed sensor? Little confused because when I did my own research it said it was it was a fuel temp sensor #2 circuit open any suggestions?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Do you mean C1227?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: ABS codes?
    The car does nor have a fuel temperature sensor and even if it did, it has nothing to do with the EBTCM.
    C1227 - Left Rear Excessive Wheel Speed Variation
    That generally means the wheel hub must be replaced, but first you make sure the connector to the left rear wheel is properly connected, clean and dry.
    Apr 2013
    Gaithersburg
    8
    Sep 2010
    East Boston MA.
    29
    26,323
    Put the scan tool away, go to the top of the Eldorado/Seville page, and read the "sticky" thread on how to pull codes from the DIC.
    It has to be C1227. The wheel speed sensor is replaceable separately in the rear, but check the hub assembly for play.
    Apr 2013
    Gaithersburg
    8
    Ok so now it say tcs c1227 history and the only current code is Pzm b2719
    Sep 2010
    East Boston MA.
    29
    26,323
    It is possible for the wheel speed sensor to trigger codes intermittently as it begins to fail. But check the connector and wiring.
    What's the definition of the B code?
    Apr 2013
    Gaithersburg
    8
    B2719 is my trunk switch not worried about that one I screwed the bolt down so it would close all the way
    Yeah it come on every so often and stays on until I park then it won't come back on for a few days to a week
    I plan on checking the connection soon if its the cable do you know a good place to get a new one or would advance auto be good enough?
    Apr 2013
    Gaithersburg
    8
    So I pulled my codes same as before so I pulled the tire off disconnected the cable and cleaned the connections and plugged it back up. No luck any idea where I go from here? If its telling me (left wheel speed variation) do I just go ahead and replace the bearing? The cable? Or both? I want to take the next step just need a push in the right direction.
    69
    82,405
    Re: ABS codes?
    Personally I would lean towards the hub & bearing assembly (wheel speed sensor).
  13. Remove Advertisements
