Here is one of those Phantom issues for you to ponder.
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By RippyPartsDept
Cadillac Seville / Cadillac Eldorado Forum Discussion, Here is one of those Phantom issues for you to ponder. in Past Cadillac Vehicle Discussion; Discovered my outside mirrors and memory seat didn't work at all when I bought the car. Dealer had his mechanic ...
    SissyBoyFloyd's Avatar
    SissyBoyFloyd is offline Cadillac Owners Member
    Automobile(s): 99 Eldorado ETC
    Jun 2013
    North of San Diego
    68
    50
    Discovered my outside mirrors and memory seat didn't work at all when I bought the car. Dealer had his mechanic simply replace a fuse and both work good now. Here is the issue now: Before this my horn would beep when I locked the car with the remote. Now after the fuse replacement work, everything works but the horn doesn't honk any longer when I lock car with remote. Strange, isn't it! Any thoughts?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Re: Here is one of those Phantom issues for you to ponder.
    Isn't there a setting to sound the horn at lock? I vaguely remember something like from when I owned my Seville.
    eldorado_sean's Avatar
    eldorado_sean is offline Cadillac Owners Enthusiast
    Automobile(s): 98' Eldorado ESC
    Sep 2012
    Burbank, California
    740
    Its a setting you can change in the computer. Someone with the full details will probably answer soon.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,579
    Quote Originally Posted by curtc View Post
    I do believe so - under the PERSONALIZATION section -
    in the Owners Manual -
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Yup... i turned it off on my '99 deville
    ... as i recall you have to hit the lock button when the doors are already locked to sound the horn
    bwv565 likes this.
    69
    82,188
    If it's not under "Personalization", it might be under "Feature Programming".
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Page 2-81 Owners Manual Cadillac Eldorado 1999
    ...starting Page 2-79 "Memory and Personalization Features
    (If Equipped)
    " and move to:
    Lock/Unlock Confirmation
    This personalization feature allows the driver to
    program the parking lamps to blink when the lock or
    unlock buttons on the remote keyless entry transmitter
    are pressed, to program the horn to sound when the lock
    button is pressed and/or to program the exterior lamps to
    turn on when the unlock button is pressed. Press the
    YES TRIP RESET button to answer yes, press the NO
    INFO RESET button to indicate no or press the SKIP
    INFO button to skip to the next personalization feature.
    To begin programming, your vehicle’s ignition must be
    in RUN. Press and hold the SKIP INFO and NO INFO
    RESET buttons at the same time to display the
    following prompts. LOCK/UNLOCK confirmation is
    the second feature to appear. To skip past the first
    personalization feature, press the SKIP INFO button.
    LGHTS FLSH AT UNLOCK: Parking lamps blink
    twice when the unlock button on the remote keyless
    entry transmitter is pressed.
    LIGHTS FLASH AT LOCK: Parking lamps blink
    once when the lock button on the remote keyless entry
    HORN SOUNDS AT LOCK: Horn sounds when
    the lock button on the remote keyless entry transmitter
    is pressed.
    EXT LIGHTS AT UNLOCK: Exterior lamps (parking
    lamps, taillamps, sidemarker lamps, license plate lamps,
    low-beam headlamps, etc.) turn on when the unlock
    button on the remote keyless entry transmitter is pressed
    and it is dark outside. These lamps stay on for about 20
    seconds or until the key is turned OFF.
    The prompts listed here appear in the same order as
    displayed on the DIC. FEATURE ON appears when a
    yes response is made and FEATURE OFF appears with
    a no response. To skip to the next personalization feature
    (REMOTE RECALL MEMORY), press the
    SKIP INFO button.
  10. Remove Advertisements
