Front Window gets little hazy inside after wiping it down every couple days or so - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Cadillac Seville / Cadillac Eldorado Forum Discussion, Front Window gets little hazy inside after wiping it down every couple days or so in Past Cadillac Vehicle Discussion; System OFF, last setting 60 degrees, and sunroof in VENT....
  1. #16
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    Re: Front Window gets little hazy inside after wiping it down every couple days or so
  2. #17
    9302Eldug is offline Cadillac Owners Fanatic
    Automobile(s): 93 and 02 Eldorado
    Apr 2012
    Oakley CA
    60
    224
    Wow air freshener. My car does the same thing and it started when I started using those air fresheners that clip onto the HVAC vents. And I thought it was from me smoking!
  3. #18
    68
    82,070
    I use those air fresheners as well. No such problem. It probably IS the smoking.
    P.S.
    Don't let that stuff leak. It'll eat the paint off the dash panels.
  5. #19
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    487
    Try using a quality glass cleaner and some newspaper. 1 wiping usually doesn't work wipe left right, then next up and down. Usually 2 or 3 if you smoke maybe more.
  6. #20
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I've seen overuse of air fresheners cloud the windows, some protectants as well.
    Newspaper works fine, the reason they're suggested is that some of the better paper towels contain setting agents that can cause streaks. I use cheap paper towels and Invisible Glass.
  7. #21
    Feb 2003
    california
    69
    6,663
    I did mean "should" I read all the time about people using this system like a manual A/C heater. Letting the system work as designed prevents early wear on fan switches, blower motors and related components. And like Ranger I very seldom have windows down.
  8. #22
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    On my Cadillacs I've always left the climate control on econ unless I wanted AC and rarely adjust anything else. If it's summer and hot out it's usually left in auto.
  9. #23
    SissyBoyFloyd's Avatar
    SissyBoyFloyd is offline Cadillac Owners Member
    Automobile(s): 99 Eldorado ETC
    Jun 2013
    North of San Diego
    68
    50
    Well so you will know: I cleaned the window good with Windex and clean towel and it has been a couple days now with no haze returning. Will update if that changes. I just sprayed Armor All on towel and rubbed down the dash and door areas last evening. Haven't checked it out today yet. Will see how she looks in a bit.
  10. #24
    Sep 2010
    East Boston MA.
    29
    26,325
    Armor All has never given me a problem.
  11. Remove Advertisements
