2001 STS will not start after car Driving .
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Like Tree5Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 STS will not start after car Driving . in Past Cadillac Vehicle Discussion; Hi Could use some Help. After driving 20 miles or so. If I turn car off will motor will not ...
    PeterS is offline Cadillac Owners Member
    Automobile(s): 2001 (Seville) STS
    Feb 2008
    Staten Island,Ny 10309
    58
    81
    Hi
    After driving 20 miles or so. If I turn car off will motor will not turn over.
    All Lights come on. If I waite 10 min. car then starts.
    What could it be?
    Thank You
    Pete
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Doesn't turn over?
    Does it crank and not start? Or not crank at all?
    Feb 2008
    58
    81
    Re: 2001 STS will not start after car Driving .
    Hi
    Thank You.
    No motor does not crank. But all the lights come on . Seat goes into Memory Mode.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Feb 2008
    58
    81
    Thank You.
    I will go and check.
    Hello
    Here are the codes that came up.
    C1287
    C1288
    U1064
    U1255
    U1016
    U1096
    Volts 9 Below=B1327
    B1328 = Volts Above 15
    B1016
    Please Help Tell me about the Codes.
    Thank You
    Pete
    68
    81,926
    Reread post #4.
    How old is your battery?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by PeterS View Post
    Thank You.
    Hello
    C1287
    C1288
    U1064
    U1255
    U1016
    U1096
    Volts 9 Below=B1327
    B1016
    Thank You
    Pete
    within the link I supplied -
    is a link to a site that lists all the codes - AND THEIR DEFINITIONS -
    Feb 2008
    58
    81
    I only have the car for a year,bought it used.
    I do not know how old Battery is.
    The U codes I hear are nothing to worry about. The C Codes are about Steering.
    The B1327 and B1328 has to do with Volts. One says Volts fell below 9 volts the other say Volts went above 15 Volts.
    Do not understand. Could it be the Altantor?
    Please advise.
    Thank you
    Pete
    68
    81,926
    I'd use a DVM to test the battery voltage, both static and while cranking (load test). If you don't have a DVM or don't know how, take it to an auto parts store and have them do it.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Please advise.
    Thank you
    Pete
    it COULD be a lot of things -
    the battery would be on the top of my list -
    you should have it load tested -
    Feb 2008
    58
    81
    Hi
    Good Idear.
    I can have it checked for free at Autozone.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Hi
    Good Idear.
    and if it DOES test bad -
    DO NOT GET A BATTERY FROM AUTOZONE -
    Feb 2008
    58
    81
    Hi
    I could take it to a repair station and Buy a Interstate Battery.
    What Battery would You Buy?
    Thank You
    pete
  16. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Hi
    Thank You
    pete
    you can have AZ TEST it - just don't buy one from them -
    I buy Walmart batteries -
    the group 79 MAXX is the one for your car -
  17. #15
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    I just replaced my battery last Saturday. I had enough, every cold day in winter was sure dead battery, I bought a battery charger (more expensive than the actual battery), probably I end up using it 10 to 15 times over the winter (and even last winter it had problems once or twice). When the weather got warmer I finally was able to put it away until last week when I had to move the car out of the garage and open close doors/trunk several times during the day. In the eve when I was to drive the car back in the garage, totally dead battery! I was in denial, cannot be is less than 3 years old battery and is AcDelco. This battery was a warranty replacement for the previous AcDelco that lasted only 1 year (if so). The shop discovered they installed originally a smaller battery than required. And that battery was to replace the Interstate I had before replacing the original AcDelco battery and this Interstate was good for only 3 years (I blame it on being an Interstate) as the original AcDelco was good for almost 8 years.
    So I have never bothered to check the battery type, I just made sure is AcDelco (what I paid for) and that's it.
    Well this time I bought the battery myself from the dealer parts counter (not going to a shop) and I kind of notices is a bit larger than I was expecting. When I replaced the battery, clearly the old one was smaller so I checked the label, it was a freakin' group 75 6YR battery instead of 78 7YR (what is required for my car). I don't even want to think what was the previous battery (I clearly remember it was significantly smaller than the group 75 one).
    So now thinking back, maybe there was a reason why I had to replace the alternator 3 times after the original battery was gone.
    So hint, hint...really pay attention to what battery you get. A '98+ Seville takes group 79 AcDelco, that is in case you diagnose a bad battery and not a loose ground or corroded battery terminals.
  18. Remove Advertisements
