Rushing water sound in dash on acceleration
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Submariner409
Cadillac Seville / Cadillac Eldorado Forum Discussion, Rushing water sound in dash on acceleration in Past Cadillac Vehicle Discussion; I know this sounds strange, but I hear rushing water sounds (like water & air through a pipe) whenever I ...
    ocgltd's Avatar
    ocgltd is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    Oct 2008
    London Ontario
    300
    I know this sounds strange, but I hear rushing water sounds (like water & air through a pipe) whenever I accelerate my 2001 STS from idle.
    I can't tell exactly where the sound is coming from, but I hear it in the cabin while sitting in the drivers seat. I sounds like it might be coming from inside the dash.
    I recently replaced the rad, so my first thought was air trapped in the heater core. But after driving 2000 miles any air should have bled out (according to other posts).
    Anyone have an idea?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Have you checked the purge line?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,816
    Re: Rushing water sound in dash on acceleration
    ............. or, the condensate drain for the HVAC system is plugged and the drain sump is full of fresh water. Many questions and threads on this - Cadillac Tech Tips, Ranger's posted locator diagrams, Google "cadillac forums 2001 seville air conditioning drain" or something close.
    Car up on a lift - look for a rubber drain elbow, maybe behind insulation, at the lower firewall/body edge just under a front seat passenger's left heel area. Clean it out with a fuzzy pipe cleaner from a craft shop or something similar.
    jcornv15 likes this.
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    Is the "purge line" a line from the water pump to the purge tank? (Been googling). If so, how/why would that cause the rushing water sound on acceleration heard in the cabin?
    If you think it's just a loud water sound through the purge line I should be able to check that while looking under the hood and pulling the throttle. But what would that mean? Plugged purge line?
    I found a picture of the condensate drain and I will check that. Interestingly I changed the cabin air filter right before this started. Is it possible I pinched the drain line on the inside? I had a hell of a time getting the new filters in...
    but not sure why that rushing water sound would occur on acceleration if it's a plugged drain?
    69
    82,262
    You have air in the cooling system. If the purge line is plugged, it can't "purge " the air from the system. Checking it is simple and has been explained in detail many, many times. A quick search should turn it up.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    you might be hearing coolant flowing around trapped air in the heater core -
    and the most common cause of air in the cooling system is a blocked PURGE LINE -
    the PURGE LINE is the only way of expelling air from the Northstar cooling system -
    it is a 3/8 diameter hose that goes from a hollow bolt in the thermostat/waterpump housing area of the engine - and plugs onto a nipple on the side of the SERGE TANK -
    with the engine running - there should be a gentle - constant flow of coolant - from the engine - to the serge tank -
    if there is no flow - the most likely cause is a blockage in the hollow bolt -
    follow the hose towards the engine - with the engine OFF - remove the hose - use a straightened metal coat hanger - or something similar - and poke it into the hollow bolt -
    the coat hanger should go in about 2 1/2 inches -
    once the hollow bolt is cleared - you can briefly start the engine to verify coolant flow - be sure to use some sort of container to catch the coolant so you don't make a mess -
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Why wouldn't a clogged purge cause overheating by vaporlocking the waterpump in this case as well as every other case?
    Has the coolant level itself been checked lately? If it's low, you may hear water flowing.
    Or how 'bout a partially clogged heater core?
    69
    82,262
    It can and frequently does cause overheating.
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    OK - I checked today and the coolant is flowing properly - no blockage. However, coolant in the purge tank was very low - perhaps it was sucking air back into the system? I'm guessing that when the rad was replaced a few weeks ago air got into the system, and that I just needed to add more antifreeze?!
    So I topped up the purge tank (1" below top) with coolant and I'll monitor and report back what I find in a week.
    eldorado_97's Avatar
    eldorado_97 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 STS, W/Nav
    Feb 2007
    Baldwin, Wisconsin
    27
    562
    Thats funny my car does the same thing and has done it for over a year now and it started after I put a new radiator in as well, no overheating issues what so ever either.. hmm... oh and on a side note the condensation drain is not plugged
    69
    82,262
    That can only happen if the surge tank gets too low.
    Correct, but it should only take a day or two to purge the air out of the system (if it is done correctly and properly monitored).
    That's a tad high, but as long as it doesn't overflow you're OK. On the other hand, if it is too much, it will just expel the excess so don't panic if you notice it.
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    A week later and there's still a rushing water sound on acceleration. I confirmed the purge tank is still filled to the proper level, and that coolant is circulating through the purge tank.
    Is there a special procedure to purge air from the system (or just from the heater core)? I assumed it should be automatic.
    Feb 2012
    NYC
    50
    1,948
    Automatic.
    Try back-flushing the heater core.
  16. #14
    Feb 2006
    56,816
    Do 3 successive WOT's.
    Read all about it up in the Cadillac Technical Archive way up ^^^ in the top black bar - "Occasional full throttle operation is good .........". Matter of fact, while you're there, study the whole thing. Lots of necessary info for a Northstar/4T80E driver.
  17. #15
    69
    82,262
    Quote Originally Posted by ocgltd View Post
    It IS automatic. If you are not low on coolant and the purge line is clear, then air is being introduced into the system.
  18. Remove Advertisements
