cranking too long before t kicks over{intermittant)
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, cranking too long before t kicks over{intermittant) in Past Cadillac Vehicle Discussion; My 97 SLS NEEDS HELP I recently had a new fuel pump and fuel filter installed because the car would ...
    paulikorg is offline Cadillac Owners Member
    Automobile(s): 1997 Seville SLS
    Jan 2010
    Northeast,Pa
    64
    95
    I recently had a new fuel pump and fuel filter installed because the car would take about 2 minutes of cranking before it would start. After the new fuel pump and filter it would start right up but during the same day if I went start it up it would take about 5 seconds of cranking before it kicked over.Now,some days it will start right up and other days it will take a few seconds of cranking
    before it turns over.Any suggestions will be greatly apprieciated.
    Thanks
    Pauli
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: cranking too long before t kicks over{intermittant)
    I wouldn't worry too much about a few seconds of cranking time -
    but to answer your question - a couple things come to mind -
    IF you have a leaking fuel injector -
    the fuel pressure - after you shut off the engine -
    COULD be bleeding off through that bad injector -
    flooding a cylinder - adding to cranking time -
    another possibility is the fuel pressure regulator -
    68
    81,922
    If your long cranks times are only in hot starts, check for a leaky FPR.
    Jan 2010
    Northeast,Pa
    64
    95
    Thanks for the info. Much apprieciated.
  7. Remove Advertisements
