4t65e trans - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Cadillac Seville / Cadillac Eldorado Forum Discussion, 4t65e trans in Past Cadillac Vehicle Discussion; Dayum, 14yrs, and 180k miles. And it fails. Whatever happened to good old American craftsmanship?...
  1. #16
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
  2. #17
    Aug 2007
    mpls mn
    2,528
    I cannot find any listing for a 2000 BCB trans. 99, 01, 02 is it? I see some ventures with 3400 and bcb trans. That's ok too?
  3. #18
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: 4t65e trans
    As long as it's a BCB it will have the correct sprocket/diff setup.
    I still recommend fixing yours to avoid double labor for a possible bad used. Your choice.
  5. #19
    Aug 2007
    mpls mn
    2,528
    I am doing labor. I can pull trans. I cannot tear trans apart. My trans has 180k miles and has issues. Is another trans with 130k miles better? Yard says its ok. $200 crapshoot. No shop will tear down my trans and fix what's broke for cheap.
  6. #20
    Feb 2012
    NYC
    49
    1,948
    Re: 4t65e trans
    $200. Your own labor. Can't beat that, knock yourself out!
  7. #21
    Aug 2007
    mpls mn
    2,528
    Re: 4t65e trans
    Yep. Pulled trans. It is a 9BCB. Found a 99 venture trans. All info I see says 99 venture only came with 9bcb. But Hollander exchange says gp and venture for 99 will not swap. This trans is private party. Talked to 3 diff yards and they all say no go. Have not looked at trans so I don't know what tag says
  8. #22
    Feb 2012
    NYC
    49
    1,948
    Re: 4t65e trans
    Maybe Venture is AWD?
    If not, check tag & mounting holes.
  9. #23
    Aug 2007
    mpls mn
    2,528
    Re: 4t65e trans
    Yard says 99 gp is 1 yr specific. A 2k does not fly according to hollinder. I see ID tag info online and it says 99 venture is bcb only but 2k venture is bcb or brb. Seller has 15 trans and is 99% sure trans is 99venture. I am going to check it out tomorrow
  10. #24
    Feb 2012
    NYC
    49
    1,948
    Re: 4t65e trans
    Found these:
    There are also several others that will work. (3.29, 35/35, FLQB, no IMS)
  11. #25
    Aug 2007
    mpls mn
    2,528
    Re: 4t65e trans
    cool. I did come across those charts also. it is a 9bcb. and it is installed now. got about 1hr of bits to finish up tomorrow and than we will see. much smoother job than my Seville. 210lbs vs 295lbs.
  12. #26
    Aug 2007
    mpls mn
    2,528
    Finished. Shifts fine. Got 3rd gear too. Woohoo. Seized brake caliper from over extended piston due to totally worn pads messed up the axle install process. It's always something unplanned to complicate job. Not that removing trans is ever easy. I think a gp trans job is MUCH easier than Seville.
  13. #27
    Feb 2012
    NYC
    49
    1,948
    Re: 4t65e trans
    Quote Originally Posted by stoveguyy View Post
  14. Remove Advertisements
