Replaced TPS and now there is clicking from ICS need help
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Replaced TPS and now there is clicking from ICS need help in Past Cadillac Vehicle Discussion; hi everyone i am new to this forum and hopefully im posting in the right place. i have a 94 ...
    eliasjere is offline Cadillac Owners Member
    Automobile(s): 94 eldorado
    Jul 2013
    27
    3
    hi everyone i am new to this forum and hopefully im posting in the right place. i have a 94 eldorado that is having problems. The idle is high above 1000 and the rpms go up and down while driving and will eventually keep doing it even at idle then it will stall. The codes i got before i replaced the TPS were po22, p036 and p070 all history. i have cleaned the egr and removed it and problem still was happening then i unplug the TPS and the problems went away. when i hooked it back up problems came back. so i assumed bad TPS. so when i replaced it with new one and turn the key to the on position the ICS started clicking instantly and the idle was still high and having the same symptoms. The ICS was not clicking before i changed TPS. And it clicks with the car on and off but it eventually stops. Codes im getting now are p022 current,p026 history, p032current, p036 current p039 history, p070 hitory, p095history, p099history and p103 current. Im stuck and really dont know what to do. if anyone could help please do so. i can give you anymore info you might need to help me.
    Jul 2013
    27
    3
    Re: Replaced TPS and now there is clicking from ICS need help
    Well I figured out that I needed to re learn the ISC after replacing the tps. . I guess no one on this website could figure that out. This forum is no good. Atleast to me it wasn't. Out of 178 views and no comments. Wow people. Come on. Help a newbie every once in awhile. If the situation was turn around I'm Sure you would understand. But I know it's hard to think abount being in someone else's shoes. God bless everyone. Hope this post helps someone else.
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Glad you figured it out.
    Could have done without the smart arse no good forums comments... you know could be no one had any ideas what to do you know, including me.
    Cheers
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It's been over a month, you could have bumped the thread at least once, nobody looks past the first several pages. Code definitions would have helped as well.
    This forum's no good? Ok ...See ya.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Quote Originally Posted by eliasjere View Post
    OH! ISC, not ICS.....
    Of course, now I get it.
    Sometime a search instead of a post will give you the answer.
    http://www.cadillacforums.com/forums...elearning.html
    68
    82,081
    1. Codes without their definitions are meaningless.
    2. If no one answered it's probably because no one had an answer.
    3. Comments like "This forum is no good" won't get you any help.
    4. Try the other Cadillac forum.
    Bye
    Jul 2013
    27
    3
    You guys are right. I shouldn't say things like, This forum is no good. This forum is actually a very good one with lots of informative people and interesting topics . I can only blame it on my igronence and lack of communication skills. I won't say things like that again.
    68
    82,081
    You are forgiven my son. Say two Hail Mary's and go in peace.
    ctmoney219 is offline Cadillac Owners Member
    Automobile(s): 1992 Eldorado 1998 seville sts 1991 deville
    Jun 2013
    27
    47
    you need to calibrate tps re learn isc or your going to need a new isc sensor its 150 bucks
  12. Remove Advertisements
