Results 1 to 11 of 11
Thread: Electrical issues, all door locks, trunk release, gas cap?
    stsdad is offline Cadillac Owners Member
    Automobile(s): 2000 STS
    Aug 2012
    Cincinnati Ohio
    55
    22
    Hi, have several codes related to the drivers door module, didn't buy one yet because in addition to all the door locks not working, the interior lights are out, as well as the trunk release and the gas cap door. Is it possible that I have a loose ground? I just went to the bone yard and pulled the front and rear fuse boxes from a 2001 DHS, I now have plenty of relays to try but would like some help so I'm not just bumping around in the dark.
    Thanks!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Re: Electrical issues, all door locks, trunk release, gas cap?
    Before you start easter-egging modules, check the valet switch in the glove compartment. (Trunk pop and fuel door pop)
    The driver's door switch panel and the interior lights are different modules.
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    393
    Have you checked for diagnostic codes?
  5. #4
    Aug 2012
    Cincinnati Ohio
    55
    22
    OK, checked the valet switch, it's off. Pulled the following codes...DDM U1255, DIM U1255, IPC 1000, IPMU1255, AMP 4713, DIM 3219, IPC 2456,MSM 9594, RFA 2579. I had just pulled codes about 2 weeks ago, all was fine except an occasional code for the front knock sensors. I'm wondering if I have an issue in the front fuse box, when I pulled the engine I noticed one of the terminals had some black around it, cleaned it up an put some contact grease on it, seemed fine. Now I suddenly have several isssues that have appeared all at once, and yes I realize the trunk/gas cap, interior lights, and door locks are all separate systems.
  6. #5
    Nov 2008
    SW Ohio
    36
    393
    any of the modules report "No Data"?
  7. #6
    Aug 2012
    Cincinnati Ohio
    55
    22
    How would I determine that? I am still suspecting the drivers door module, but would be very interested in knowing more.
  8. #7
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    It would say "NO DATA" instead of displaying codes or "NO XXX CODES".
    Codes are meaningless without definitions.
  9. #8
    Aug 2012
    Cincinnati Ohio
    55
    22
    OK, no IRC data, No IPM data...
  10. #9
    Nov 2008
    SW Ohio
    36
    393
    Disconnect the battery for 10 minutes to see if those modules come back online when you reconnect battery power. I had an issue once with the RIM module not communicating. Unhooked the battery and the module started communicating again. A "No Data" message means that module is not talking to the rest of the modules for some reason.
  11. #10
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Check the radio fuse, if blown, replace then turn off the valet switch in the glove compartment.
  12. #11
    Feb 2006
    56,854
    dogottie, please do not hijack threads. Start your own, stating YOUR problems with YOUR car.......... That way all replies are for you, not several other members. Thanks.
    You need to get up to speed on your car's maintenance and repair - start by reading all the sticky posts at the top of this page as well as at the top of the Engines; Northstar Performance page.
    "Speed limited to 90" is a suspension fault. As in the stickys ^^^, learn to use your car's built-in code scanner/memory to see any trouble codes that may be set by monitored systems.
  • You may not post replies
