00 Eldorado turn signal problem
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 00 Eldorado turn signal problem in Past Cadillac Vehicle Discussion; Hey All, Thought I would ask the experts this one. I have a new to me 2000 Eldo w/73000 miles. ...
    GibsonLPfan is offline Cadillac Owners Member
    Automobile(s): 2000 Eldorado ETC
    Jun 2013
    Hey All,
    Thought I would ask the experts this one. I have a new to me 2000 Eldo w/73000 miles. Every thing was working fine until last night the directionals didn't work, but after awhile of driving around they started working again but at first the blink timing seemed slow then again after awhile seemed to be normal. Now this morning they are not working again.
    Now the hazards work fine and the side turning lamps light up when the directional lever is moved up or down so not thinking switch in the column. Any input on this would be appreciated.
    Edit: Started working again this morning after running awhile??? Also all bulbs are working and no current codes are present.
    JGD's Avatar
    JGD
    JGD is offline Cadillac Owners Member
    Automobile(s): 2001 Eldorado ESC - Sold!
    Apr 2012
    Mad Town, WI
    48
    Re: 00 Eldorado turn signal problem
    Well, I'm not an expert but I did just experience this problem.
    Symptoms were the turn signal cornering lights would come on, but no flashing. After driving a bit, flashing would occur. Hazards would come on and cause all to flash. After sitting a while, no flashing again.
    Simple fix:
    You need a new flasher relay. About $10 if I remember correctly.
    Only problem is, where it is located. Easiest thing to do is remove the headlight control panel, and access the relay from there. Hope you have small hands. There is a post on this somewhere, but I cannot locate it at the minute.
    Both the hazards and individual flashers are tied into one relay.
    Hope this helps!
    EDIT: Here's the link to the post of the location of the relay, and how to change it!
    http://www.cadillacforums.com/forums...-location.html
    Jun 2013
    Thanks JGD, I got this fixed, that relay is hard to find for sure!
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    FWIW, In the 2000 and later Sevilles the hazard flasher and turn signal flasher are part of the hazard warning switch in the center of the dash. To repair either one you replace the whole switch. The old price was $40 and labor was 0.6 hour.
  7. Remove Advertisements
