1990 eldorado over heating and coolant boiling
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1990 eldorado over heating and coolant boiling in Past Cadillac Vehicle Discussion; hey all I am new here and I am having some problems with my 90 edlo. The car has just ...
    gonente is offline Cadillac Owners Member
    Automobile(s): 1990 cadi eldorado 70,000 miles
    Jun 2013
    26
    3
    hey all I am new here and I am having some problems with my 90 edlo. The car has just under 70k and I took it the other day to get emission and it over heated!! I thought that it may be the relay and I changed that but a couple hours later it went to 235 again. the coolant is boiling at about 235 or so, so I am going to change that out today it has a fairly new thermostat and a new coolant fan. the last idea I had was maybe the radiator cap, the coolant over flow always stays the same and is always at the same level. also I had the engine apart a few months ago and the water pump was good with no play. I had few problems with the car getting hot in the past that's y it has a new thermostat and new fans. I am out of ideas any got any suggestions please.
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    Pull off the grill and check if the driverside of the condenser is covered with dirty grease. Mine was running hot until I discovered this.
    68
    81,761
    Re: 1990 eldorado over heating and coolant boiling
    I'd try the cap first. If it can't hold pressure, it's gonna boil at a lower temperature.
  5. #4
    EldoRedo's Avatar
    EldoRedo is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ETC (Crimson)
    Jul 2006
    Bethesda, Md.
    232
    When you say "the coolant over flow always stays the same and is always at the same level," do you mean even when the engine is cold?
  6. Remove Advertisements
