cooling issues
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, cooling issues in Past Cadillac Vehicle Discussion; Ok caddilac gurus I'm still having cooling problems I'm not car illiterate but I've never seen a head gasket leak ...
    stealth92 is offline Cadillac Owners Member
    May 2013
    4
    cooling issues
    Ok caddilac gurus I'm still having cooling problems I'm not car illiterate but I've never seen a head gasket leak internal or external that you don't loose fluid so I took the t stat out and the temp still went half way up the gauge and check coolant level came up the overflow was full if gaskets need replaced are these thread serts or studs required and do you really have to pull the engine to change them please no smart comments I admit the northstar is foreign to me but I've bone a lot of auto repair from tranny rebuilds to motor rebuilds thanks for you're time
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What year/model?
    "Half way up the gauge" is normal. Is the car overheating?
    If the surge tank is "full" (half way up?), and the CHECK COOLANT LEVEL message is coming on, the float in the tank is stuck. You might be able to free it by removing the tank, filling it with hot water, and shaking it. Otherwise it will have to be replaced.
    If the heads are removed, you ABSOLUTELY need to use studs or inserts in all 20 head bolt holes. It is possible to insert the block with the engine in place, but much more difficult, risky, and not recommended. Studding is not possible with the engine in place, there is not enough ro to get the rear head over the studs, the firewall would be in the way.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,492
    Re: cooling issues
    since you are asking questions on a Cadillac site -
    I GUESS you have a Cadillac of some sort -
    and since you removed the thermostat -
    it must be a water-cooled engine -
    not very much information to go on -
    ooh - another clue at the end -
    your head gaskets might not be to that stage - YET -
    the proper FULL COLD level in the SERGE TANK -
    is actually about 1/2 FULL - right where is says FULL COLD -
    if the coolant IS at the proper level -
    the float in the SERGE TANK is stuck - or defective -
    YES
    some have tried without removing the engine -
    at the end - MOST have said if they were to do this job again -
    they would remove the engine -
    boy - you're no fun at all -
    so - how often do you BONE auto repair -
    have you talked to anyone about this?
    if you are concerned about failed head gaskets -
    do a COOLING SYSTEM PRESSURE TEST -
    next - do a BLOCK TEST -
    if you don't know what these are - do a SEARCH -
    they have been discussed a million times -
    oh - one more thing -
    PUNCTUATION MARKS are your/our friend -
    it helps to organize your single giant run-on sentence -
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: cooling issues
    ^Yea. Did you pressure test the system?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,283
    Re: cooling issues
    .......... and a Northstar will not cool correctly without the proper thermostat in place. Yes, you MUST insert/stud all 20 cylinder block head bolt holes. The drilling, tapping, inserting and total cleanup will take a dedicated long day's work - that's AFTER the engine removal and preparation work. The GM shop rate is 22 hours in a shop with all the special tools, fixtures, parts and experienced techs. You will need a real GM/Helm shop manual because of all the special techniques, torques, and assembly procedures. A Northstar in no way resembles a Chevy 327.
    I'm having a sale on punctuation, spelling, grammar, and capital letters.
    stealth92, You might want to read the 4 threads - the sticky threads - in the Engines, Northstar Performance forum. Cooling system, temperature gauge, and Northstar head gasket failures - and repair procedures - are discussed at great length.
    68
    82,084
    Re: cooling issues
    Quote Originally Posted by Submariner409 View Post
    That WOULD make reading a little easier.
  9. Remove Advertisements
