'96 Eldorado, Severe Spark Knock Under Moderate/Hard Acceleration
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, '96 Eldorado, Severe Spark Knock Under Moderate/Hard Acceleration in Past Cadillac Vehicle Discussion; So, my Eldorado has 80091mi, has always been run on premium 91 octane with no Ethanol in it, the best ...
    EldoradoKid's Avatar
    EldoradoKid is offline Cadillac Owners Member
    Automobile(s): Dark Cherry Metallic 1996 Cadillac Eldorado
    Jan 2012
    New-Brunswick, Canada
    21
    15
    So, my Eldorado has 80091mi, has always been run on premium 91 octane with no Ethanol in it, the best synthetic oil, had a full tune up with factory platinum spark plugs and has been babied all its life. In the pass year, it started to spark knock more and more frequently and I am now starting to worry. It will do so from accelerations ranging from 1500rmp up, ( really bad above 2000rpm ). Now it doesn't spark knock every time I use it, which is not very often, but it still frequently does it and its very severe and loud spark knock .
    I am looking for any help I can get from someone who knows what could be causing this problem, I am really hoping its not an expensive fix.
    Thank you all in advance, EldoradoKid
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by EldoradoKid
    All irrelevant.
    Have you pulled your codes?
    When's the last time the car's seen some WOT?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,594
    Re: '96 Eldorado, Severe Spark Knock Under Moderate/Hard Acceleration
    "Babied" is one big problem right there, and do some searching in the Cadillac Tech Tips for threads on how to clean the EGR valve and passages.
    Study the entire Cadillac Technical Archive way up ^^^ in the black bar, especially the article titled "Occasional full throttle operation is good .........".
    68
    81,768
    There are several possibilities. I am surprised you have no SES light on (Or so you?). Pull the DTC's. Post them AND their definitions.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,268
    how have you determined what you hear is SPARK KNOCK?
    have you checked for codes?
    Jan 2012
    21
    15
    So I pulled the codes, but there wasn't any that was even closely related to such a problem. I only had A/C and Traction Control codes, nothing else. And there is no SES light on.
    And I do give the car a WOT once in a while , like twice a year. Keep in mind the car is driven about 1000 miles per year only in the summer for the last 3 years.
    Could it be caused by a clogged up fuel filter? Dirty injectors? Or even by the timing being off? Is the car driven too little for its own good?
    Feb 2006
    55,594
    Post #3. EGR
    68
    81,768
    Lack of EGR can cause a spark knock, BUT, that SHOULD set a DTC and trip the MIL.
  11. Remove Advertisements
