Results 1 to 2 of 2
Thread: Memory seat module
    Cadillac R's Avatar
    Cadillac R is offline Cadillac Owners Member
    Automobile(s): 1996 Cadillac Eldorado ETC, 2001 Cadillac Deville
    May 2012
    Bloomington, IL
    40
    83
    Memory seat module
    I have a 96 Eldorado and I pressed the memory button one day to set it, the seat moved, then stopped and now it won't work at all. the passenger seat still works and the seat heat on the passenger side still works also but not the driver side.
    Does this sound like a problem with the memory seat module or the seat motor? I don't think it can be the fuse under the hood because the passenger seat still works.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Pull your codes, i think if it's the module it'll throw out an MSM B code
  • You may not post replies
