Ignition Coil diagnostic
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Ignition Coil diagnostic in Past Cadillac Vehicle Discussion; Is there any way to test an ignition coil? I have been getting misfire codes, I changed spark plugs & ...
    Dviper23 is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Cadillac Seville SLS
    Nov 2011
    36
    108
    Is there any way to test an ignition coil? I have been getting misfire codes, I changed spark plugs & boots a few months back & it temporally fixed the rough start & idle but its back, I tried the local junkyards for an ignition coil but no luck, so I would have to buy a new one to test it & they cost about $200 which is too much to spend on a maybe
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,528
    Re: Ignition Coil diagnostic
    Yes there are test procedures.
    A factory service manual can be very handy
    http://www.faxonautoliterature.com/2...et-p13983.aspx
    Probably some used ones around if you search
    Some people like an AllData subscription.
    http://www.alldata.com/
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,554
    Not really - the primary winding of each coil is connected to the ICM multi-pin connector in the coil cassette L-leg. You would need a circuit diagram of the connector to ohm out those windings. The secondaries each go from the coil tower to the cassette ground spring.
    You might talk to Chris in parts at Rippy Cadillac over there >>>>>> or keep your eyes on RockAuto for a blowout on DELPHI cassettes.
    The cylinder pinout order in this pic is for Bank 2 (left, front bank). Bank 1 (right, rear), in the same pin order, is 5,3,1,7.
    Don't check resistances across the ICM itself - VOM voltage is too high for the internal circuits - it comes out with 2 screws and 2 (careful ......) snap clips. More pins way into the cassette recdeptacle. Both ICM's, as both cassettes, are identical.
  5. #4
    68
    81,750
    Testing one of these coils is not as easy as the old single coil used with distributors.
    You could use one of these, but they are not cheap either.
    http://www.sjdiscounttools.com/wae76562.html
  6. #5
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,261
    just to be clear -
    any Northstar powered Deville - Seville - or Eldorado - even Olds Aurora -
    that has the ignition cassette will work -
    and the only difference between the front - gray - and rear - black coils is color -
    if you still can't find one locally -
    try Ebay - you can usually find them for around $75 -
  7. #6
    Nov 2011
    36
    108
    Thanks for the help & suggestions, I got some diagnostic stuff I'm gonna try, first I need to see which cylinder(s) are misfiring, yes I did put in 8 brand new plugs not too long ago but I did have a top rad hose leak that sprayed coolant onto the ignition coil bolts above the plugs, also there is a very small crack along the plastic that surrounds the metal on the ignition coil that goes into bank 2,...now only if we could get 1 day without rain so I can tinker with it
  8. #7
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    If you have a specific cyl misfire code, you can switch coils to see if it moves to the other bank.
    I don't know what they were thinkin' when they designed these 4 in 1 cassettes.
  9. #8
    Nov 2011
    36
    108
    Quote Originally Posted by Aztec ETC ECS
    If you have a specific cyl misfire code, you can switch coils to see if it moves to the other bank. I don't know what they were thinkin' when they designed these 4 in 1 cassettes.
    Do you mean to switch the back & front coils? Wow it's so simple I have no idea how I never thought of trying that lol, thanks & if the rain holds off tonight I will give that a try & hopefully this will narrow my issue down
  10. #9
    Feb 2012
    NYC
    49
    1,948
    ^ Yeah. And like Bass said, the only difference is the color.
  11. #10
    cliff77 is offline Cadillac Owners Member
    Automobile(s): 93 sts
    Feb 2013
    nashville tn
    46
    21
    Rock auto is where I got mine. $80 for all 4.
    Also I had a bad ignition control module. The coil packs sit on the icm. $200 for the icm.
    Easiest way to find a bad coil pack is to swap them around. The bad on will show. Good luck
  12. #11
    Feb 2006
    55,554
    cliff77, Your ignition system is VERY different from the 2000 and later systems. Absolutely NO resemblance. (For yours, Google "waste spark ignition")
    Here's what the OP is fooling with - 2 per engine ...................
  13. #12
    Nov 2011
    36
    108
    I took the car to get a full estimate on all things wrong, & they found the head gasket needs to be repaired got quoted up to $1800, they said normally they recommend not to bother but said at under 108K & the condition of my vehicle that its probably worth repairing.....any suggestions? I believe I am leaning towards getting it fixed because if I were to put $2500 into this car it will be in hopefully great condition for at least 3 more years, when in contrast I'm not going to find a very good car for under $3000
  14. #13
    Feb 2006
    55,554
    We would need a LOT more proof that the head gaskets are bad from having only simple misfire codes .............. and, considering the PROPER work to prepare the block for new head bolts or studs, $1800 is about $600 - $1500 too low.
    How much homework have you done in Engines, Northstar Performance - the stickys on cooling system operation and head gasket failures ???
    www.sjdiscounttools.com/lis75500.html
  15. #14
    Nov 2011
    36
    108
    I questioned how they determined it was the gadket & they said it was the misfire, coolant leak, & blue water test
  16. #15
    Feb 2006
    55,554
    Maybe good info - but a real bummer for you.
    If the rest of the car is in good to excellent condition, stud the engine. Where are you ?? (Upstate NY ??)
    vincentm likes this.
  17. Remove Advertisements
