Battery Voltage
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Battery Voltage in Past Cadillac Vehicle Discussion; My battery with car turned off reads 12.2, can you guys tell me how much life it has left. Thank ...
    Amir A's Avatar
    Amir A is offline Cadillac Owners Member
    Automobile(s): 2003 Seville SLS 115K mi, 2008 Dodge Charger 45K mi
    Apr 2013
    Glendale, CA
    57
    53
    Battery Voltage
    My battery with car turned off reads 12.2, can you guys tell me how much life it has left. Thank you in advance.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No.
    Having electrical/starting problems?
    At that voltage, I'd have it load tested just in case.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,220
    Re: Battery Voltage
    The ONLY way to get some idea of remaining life is to have a parts store perform a battery load test. If the battery is 5 years old or more, it's on its last legs.
    Because our cars place such a tremendous load on the battery with the key on, DIC voltage is no indication of much value. With the engine running, the DIC will show the present charging system voltage, not necessarily battery voltage.
    The proper way to see true battery voltage is to disconnect the battery from the vehicle, let it sit for a half hour, then measure voltage with a digital VOM.
    Amir A's Avatar
    Apr 2013
    Glendale, CA
    57
    53
    Re: Battery Voltage
    Thank you Sub for the information, I just wanted to get an idea since I don't know when the previous owner replaced the battery, when car is running, DIC shows 14.8, is that normal?
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes.
    Feb 2006
    56,220
    Re: Battery Voltage
    Quote Originally Posted by Amir A View Post
    As posted, yes. An automotive charging system always maintains a slightly elevated voltage, even when the battery is fully charged. The voltage regulator ramps down charging amperage at full charge to only that value needed to run the car and accessories and "float" the battery on the system. My STS runs at 14.4 - 14.8 VDC day and night.
    Ranger is online now Cadillac Owners Member
    68
    82,066
    Re: Battery Voltage
    There is really no way to predict when a car battery will die, any more than we can predict when you or I will die. Some last 4-5 years (closer to average) and I've seen others go 10 or more (not common). Generally speaking, somewhere between the two is probably average (though that's a fairly large spread) and that is determined by a lot of factors like heat. Batteries generally last much longer Minneapolis. than they do in Phoenix.
    Amir A's Avatar
    Apr 2013
    Glendale, CA
    57
    53
    Re: Battery Voltage
    Thank you very much Sub and Ranger. I can always count on you guys for information on my car.
  11. Remove Advertisements
