slop in seat track?
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, slop in seat track? in Past Cadillac Vehicle Discussion; It has always bothered me that everything 'adjusts' every time you get in and out of the car. I like ...
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    slop in seat track?
    It has always bothered me that everything 'adjusts' every time you get in and out of the car. I like the Driver 1/2 creature feature but it just translates to excessive wear. Has anyone experienced a little slack in the drivers seat track? It tends to slide backwards a little when you accelerate. Is there a common failure point?
    SwampeastMike is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS, White Diamond
    Nov 2008
    Cape Girardeau, Missouri
    53
    782
    Re: slop in seat track?
    You can use the personalization features in the DIC to stop the seat and steering wheel from moving. Turn the "Key in Recall", "Auto Exit Seat" and "Auto Exit Steering Wheel" function off. Even with the automatic movement, a few seconds operation of a very strong, very slow moving mechanism is insignificant wear. There are even so-called "soft" stops built in that in normal operation electrically stop travel just a bit before it physically ends.
    The slack you feel in the seat is most likely just from loose mounting bolts. There are two at the rear of the seat (large Torx head bolts)--the inboard one is under the cover on the floor; the outboard one is horizontal in the seat track itself behind a plastic cover in one of the oval-shaped holes in the track. (Metal tangs slide into slots in the floor at the front so there are no fasteners at the front.) The factory spec of 30 ft/lb for the seat bolts doesn't seem to be enough so I tightened mine to 45 and no more slippage.
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 Honda Accord LX. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    27
    3,718
    Quote Originally Posted by EcSTSatic View Post
    Mine always did this! Never could figure out why it did it. Hopefully my Deville won't do this.
