Intermittent Stalling - tach drops to 0, dash blacks out too.
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Intermittent Stalling - tach drops to 0, dash blacks out too. in Past Cadillac Vehicle Discussion; "99" Seville sts, Stalls intermittently, sometimes just cranks over, I notice if I insert the key and turn it to ...
    jmullsy's Avatar
    jmullsy is offline Cadillac Owners Member
    Automobile(s): 99 Seville sts
    Aug 2012
    New England/ NH-MA
    41
    19
    "99" Seville sts, Stalls intermittently, sometimes just cranks over, I notice if I insert the key and turn it to on, then listen for the bing bing bing (sound 3X's) then it will start. If I dont do this procedure it will not start- most of the time. I've read up and figure Cam sensor and or Crankshaft sensor also am now considering the "ignition sensor or module" Any advice where to start first?? I'm on my own with no diagnostics..I just paid a scammer mechanic A LOT of money for him to swindle me and say the job is done,, I assumed it was fixed..turns out the job he thought was gonna fix it "a leaking intake gasket" was done but my initial problem was not fixed!!!! Raymonds hilltop Lowell Ma. fyi - Scammers!!! still I need help does my explanation of intermittent stalling and dash problems tell anyone anything? please help me!! It's an otherwise beautiful car!! Still runs and can get me from A to B but I do notice in rain it's not intermittent its inevitable to stall every half mile...thanks to anyone who can help. I also don't know where any of these are located other than the Crankshaft sensor. Where is the cam and ignition module?? should I do all 3??
    69
    82,161
    Re: Intermittent Stalling - tach drops to 0, dash blacks out too.
    Start by using the onboard diagnostics and pull your own codes. Post them AND their definitions. See the DTC Sticky if you need help.
    Also check your fuel pressure.
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    It could also be an EGR valve that is sticking or not closing fully due to carbon buildup (see my post addressing my similar issue: http://www.cadillacforums.com/forums...ermittent.html).
    jmullsy's Avatar
    Aug 2012
    New England/ NH-MA
    41
    19
    Before I did the Cam sensor and the two Crank sensors, the codes I pulled were:
    C 1211, C 1235, C 1276,C1295. and all P0201, through p0208. then P 1574, P1599, P 1646. After I did just the cam sensor, the car ran allot better seemingly. Until I did the 2 Crank sensors. I Still have the same problem. Intermittent stalling, Do I have to have the computer programed after doing Crank sensors?? Do the codes help? I wonder if it has to do with my ignition module or ignition itself?? Any one?? thank you for all your time guys!
    69
    82,161
    You should not need to do the idle learn procedure. I didn't after replacing my CKP sensors and had no problems.
    Codes probably would help if you provided their definitions. No one has them memorized.
    jmullsy's Avatar
    Aug 2012
    New England/ NH-MA
    41
    19
    sorry these are the codes and meaning but its Before I did the Cam sensor and the two Crank sensors .....so, the codes I pulled were:
    C 1211 (ABS indicator Malfunc), C 1235 (RRwheel speed circuit), C 1276 (Delivered torque signal cirucuit Malfunc),C1295 (Break lamp switch circuit) . and all P0201, through p0208 =(are all Injector control circuit for cyl 1-8 ). then P 1574 (stop lamp switch circ.) , P1599 (Engine stall or near stall detected), P 1646 (evap Vent Solenoid Circiut) I just replaced the solenoid as well??. After I did just the cam sensor, the car ran allot better seemingly. Until I did the 2 Crank sensors. I Still have the same problem. Intermittent stalling, Do I have to have the computer programed after doing Crank sensors?? Do the codes help? I wonder if it has to do with my ignition module or ignition itself?? Any one?? thank you for all your time guys!
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,560
    Quote Originally Posted by jmullsy View Post
    Do the codes help?
    sure - that's why they are used -
    gee - THAT might be a clue -
    if the injectors don't fire - guess what happens -
    the engine stalls -
    might be a good place to start looking -
    you will need a noid - a stethoscope - and a DVM -
    69
    82,161
    NO.
    Very possible.
    That could be something common to all 8 injectors, though I'm not sure what that might be.
  11. Remove Advertisements
