oil pressure switch
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Cadillac Seville / Cadillac Eldorado Forum Discussion, oil pressure switch in Past Cadillac Vehicle Discussion; I was wondering how I go about changing this?? Any special tools needed??...
    jake99seville's Avatar
    jake99seville is offline Cadillac Owners Member
    Automobile(s): 1999 seville sls
    Apr 2013
    buffalo ny
    31
    57
    oil pressure switch
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    Re: oil pressure switch
    Apr 2013
    buffalo ny
    31
    57
    That only helped slightly.....
    Feb 2006
    55,881
    from the Tech Tips ......... and most of the links in that Google search have the How-to's in them.
    car up on a lift
    lower air deflector removed
    oil pressure sender socket
    small hands, tight work
    remove oil filter
    remove oil filter adapter
    remove electrical connector
    carefully place adapter in vise, padded
    remove sending switch
    Reverse for replacement. Probably need two oil filter adapter O-rings, dealer. Bolts to 12 lb/ft. 1/2 quart new oil. Replacement lower deflector plastic rivets on the Help! racks at parts stores. (Pull out the center pin, rivet collapses, pull rivet. Use over again.)
    Apr 2013
    buffalo ny
    31
    57
    Can I replace it without a lift?? Or should I just let a shop do it??
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    A jack and jack stands will work fine.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    it can be done without a lift... only you can answer the question of if you can do it without a lift
    68
    81,914
    Quote Originally Posted by jake99seville View Post
    Of coarse you can. It's just easier with a lift (which most DIY'ers don't have access to).
    rodnok01's Avatar
    Feb 2012
    NC
    6,630
    Can be done without removing oil filter assembly usuauly, I did remove one CKP for clearance so a socket would go on.
    Apr 2013
    buffalo ny
    31
    57
    Should I just do it along with an oil change??
    rodnok01's Avatar
    Feb 2012
    NC
    6,630
    Most people do.
    Apr 2013
    buffalo ny
    31
    57
    Would it be easier in the sense of time or work to b done??
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    easier for who?
    for a shop -
    if you are getting an oil change -
    the car would be on a hoist -
    they would remove the oil filter -
    so that might save 5 to 10 minutes towards replacing the oil switch -
  16. #14
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    It is difficult to do without removing the oil filter and filter adapter since there's very little room to work. You'll have to drain the oil when you remove the oil filter and adapter, so yes, it would be good to plan to do an oil change at the same time.
  17. #15
    Sep 2010
    East Boston MA.
    29
    26,325
    5-10 minutes? Must be one of those hand crank hoists .
  18. Remove Advertisements
