o2 sensor change
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Ranger
Cadillac Seville / Cadillac Eldorado Forum Discussion, o2 sensor change in Past Cadillac Vehicle Discussion; I have to change an o2 sensor tomorrow o was wondering if they're a bitch to do or what?? I ...
    jake99seville's Avatar
    jake99seville is offline Cadillac Owners Member
    Automobile(s): 1999 seville sls
    Apr 2013
    buffalo ny
    32
    57
    o2 sensor change
    I have to change an o2 sensor tomorrow o was wondering if they're a bitch to do or what?? I believe the one I gotta change is bank 2 sensor 1....
    Any special tools needed??
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    Re: o2 sensor change
    Cadillac Tech Tips or the same type of Google search as your other question.
    Posted many times in here and in Engines.
    B2S1 - left (front) bank exhaust collector sensor.
    69
    82,173
    You need an O2 sensor socket.
    Apr 2013
    buffalo ny
    32
    57
    Does it matter which one? When I search at advance auto parts they got a few of them
    69
    82,173
    I think any one will do the job. It's just basically a deep well socket with a slot cut down the side for the wiring.
    Apr 2013
    buffalo ny
    32
    57
    Got it done.... wasn't too bad took about 2 hours....
    Apr 2013
    buffalo ny
    32
    57
    Should I reset the "SES" or see if it goes off by it self?
    Feb 2006
    56,590
    If your replacement was the cure for the problem, the SES will extinguish after 3 successful start-run cycles during which the fault does not reappear. IF the fault is cured, the car will not be ready for an emissions test until all emissions systems have had a chance to be monitored and then set the 'ready' flags for the test set.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Does anyone replace the O2 sensors as a routine maintenance item or just wait for a code? Degraded performance does not throw a code.
    FWIW, I found this article on O2 sensors. Granted, they want to sell a tool to test them
    http://www.autotap.com/techlibrary/r...aintenance.asp
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by EcSTSatic View Post
    I'm sure you can find so-called knowledgeable folks who recommend scheduled O2 sensor replacement. But you will not find any reference to an O2 sensor replacement schedule in the Owner's Manual.
    Under a complex set of test conditions O2 sensor performance will set one or more P codes.
    And I expect they will sell a boatload of them.
    However, your Onboard Diagnostic system is constantly monitoring O2 sensor response to the PCM action of commanding the fuel mixture very slightly lean followed by commanding the fuel mixture very slightly rich and comparing the sensor voltage waveform to a known baseline. Federal EPA mandated test procedure.
    69
    82,173
    If it ain't broke, don't fix it.
    vincentm likes this.
    rodnok01's Avatar
    Feb 2012
    NC
    6,674
    Unless a code sets they probably are fine. Even with realtime scanner you gotta know what to look for when checking them.
    Apr 2013
    buffalo ny
    32
    57
    The light is off and has stayed off!!! And best of all........
    PASSED NYS inspection!!!!!
  16. Remove Advertisements
