Head gasket question - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Head gasket question in Past Cadillac Vehicle Discussion; Originally Posted by geegeeburr ....Then I found out the manifold cover is what I thought were the coils, and the ...
  1. #31
    Sep 2003
    Metro ATL
    4,854
    Re: Head gasket question
    Quote Originally Posted by geegeeburr View Post
    ....Then I found out the manifold cover is what I thought were the coils, and the coils don't look like coils at all, but more like squares. Sigh.
    Just to muddy the terminology waters a little.
    Automobile parts terminology can be confusing and/or misleading and usually has more to do with form than function. The term 'coil' is the commonly accepted contraction of 'ignition coil' which reveals no clue as to the function of the part.
    The function of what the automobile industry calls an 'ignition coil' is the same as what the science of electricity (which predates horseless buggy technology be several lifetimes) identifies as a transformer. The name transformer suggests something is being changed from one form to another and that is exactly what a transformer (ignition coil) does.
    What is changed is your vehicle's battery voltage from 12V to a value high enough to jump or arc over the 0.050" spark plug gap under 10X atmospheric pressure conditions. From 12V to something in excess of 20,000V.
    If you notice the cylindrical device bolted to the top of your neighborhood utility poles, that is a transformer and in automobile speak it would be a coil.
    Don't get me started on shock absorbers commonly called shocks.
    Are we muddy yet??
  2. #32
    geegeeburr is offline Cadillac Owners Member
    Automobile(s): 1997 Eldorado
    Jun 2013
    54
    Quote Originally Posted by JimD View Post
    Are we muddy yet??
    Do they not absorb shocks? (Albeit the physical, not electrical, kind?)
  3. #33
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes, they absorb shock, but are not themselves "shocks". Shock (absorbers) and struts are also called dampers, as they damp wheel/body motion.
  5. #34
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    geegee, You NEED to read the thread I created for you - ".050" spark plug gap". Close to this one.
  6. #35
    Sep 2003
    Metro ATL
    4,854
    The springs in an automobile suspension system are intended to smooth out the ride and isolate the passengers/cargo from every rut and bump on ''rough" road surfaces. No doubt you have seen photos or sketches of pioneers headed west from St. Louis, and frequently you see all the humans walking beside the wagon rather than riding in the wagon. Why are they walking for mile after endless mile when there are teams of horses capable of moving the wagon? Those wagons had no springs between the axles and the passenger/cargo container. Today the Interstate system mileage from St. Louis to the front range (Denver) is approximately 850 miles and many of those pioneers continued on west from there. Walking.
    Unfortunately, springs under compression or tension load tend to oscillate around their 'at rest' position when the load is removed. Spring oscillation in an automobile suspension system must be damped as quickly and effectively as possible for safety reasons as well as ride comfort. Enter the hydraulic oscillation damper A.K.A. shock absorber.
    Semantics, I know. Oscillation damper supplies a clue to what the device is really intended to accomplish. Shock absorber leaves you wondering about the source of the shock that is being absorbed.
    geegeeburr likes this.
  7. #36
    Jun 2013
    54
    IF one were going to try to do a Normsert with the engine still in the car, using a right angle drill, would that drill need to be air-powered? Or would a cordless powered by a 20-v litium ion battery be strong enough? Those lith-ion tools seem to pack a pretty good punch, IMO. At least, into wood. Mind you, that's only IF someone was gonna try it.
  8. #37
    Feb 2006
    55,919
    If you attempt the job you will need all the reliable drill power you can muster, so go with 117 VAC power and a healthy drill. Personally, I would not recommend trying to insert the block in the car......... and you'll need to do some very dedicated tape/cardboard sealing of EVERY hole, large and small, except the bolt holes. Aluminum chips will go everywhere, and you'll use a ton of air while blowing your hole work clean.
    Get into the stickys and threads in Engines, Northstar Performance for a hint of what you'll be up against. Find threads by Speedygman, JoeTahoe, AJxtcman and others in the NP stickys.
  9. #38
    Jun 2013
    54
    Thanks, Sub.
  10. #39
    68
    81,928
    You'd need a pretty big compressor to run a pneumatic drill. I'm with Sub, I'd prefer a corded electric drill.
  11. #40
    Jun 2013
    54
    I just asked that because whenever I'm at a mechanic, they always seem to be using pneumatic tools.
    Personally, I much prefer cordless- the only thing I run on the compressor are my nailers. I was hoping someone would give me an excuse to buy this really awesome 20v lithium-ion drill and driver set that was on clearance at Home Depot. They just happened to have an angle drill with the same batteries. My old 18v sets are big and bulky and not holding a charge so well any more.
  12. #41
    68
    81,928
    Shops have HUGE compressors that will run anything.
    A sale is as good as any reason to buy a new tool. Never pass one up. That said, for this application, I think you'd run down the battery long before you finished.
  13. #42
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Use a corded drill. Aluminum is soft but it's a metal after all.
  14. #43
    rodnok01's Avatar
    Feb 2012
    NC
    6,634
    Yea corded have more options, more power, max speed limiter, depth stop etc.
    Don't get me wrong, love the cordless I have and for a lot of things it is better.
    Air drills are ok but not crazy about them myself for diy jobs.
  15. #44
    Feb 2006
    55,919
    .....one hole.
    (I fixed it)
  16. Remove Advertisements
