99 STS AC problem
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 STS AC problem in Past Cadillac Vehicle Discussion; 99 seville STS passenger side vents blowing hot air even if AC switch is turned off on passenger side...
    skhantx is offline Cadillac Owners Member
    Apr 2013
    99 STS AC problem
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,248
    Re: a/c problem
    You'll get more input up in Seville. Moved.
    Likely a vent door actuator problem. Many threads on this. Study the sticky post ^^^ "How to pull codes" and then use the embedded link to get any definitions of codes found. Post it all here.
    Look in Discussions - Cadillac Tech Tips (many pages of threads) on how to get to and replace the several door actuators.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: A/C mode problem - 1996 Seville
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Apr 2013
    99 STS AC problem
    Driver's vents cold
    Passenger side hot
    Even if passenger side turned off
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: 99 Seville STS AC problem
    You'll likely get better and more timely responses by posting in the Seville forum. This area is for the 2005 & up RWD & AWD STS which is quite different. In our cars, low freon affects the passenger cooling first. I can't say if the same is true on yours. I had a '98 but never had that issue.
    Feb 2006
    56,248
    Re: 99 STS AC problem
    Please do not start double threads on the same problem. Your other thread, posted in another incorrect forum, was enough to get the problem on the path to diagnosis. Let the thread work for you - it might take a bit of time - but the info will all be in the same place.
    68
    82,072
    Have you pulled the DTC's as advised in Post #3?
    Probably a failed actuator.
  10. Remove Advertisements
