Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: 1999 SLS Left Turn Signal
    JSaunders is offline Cadillac Owners Member
    Automobile(s): '99 Seville SLS
    Jun 2013
    25
    10
    I just bought a '99 Seville SLS from my brother. Car has been sitting for the winter. He said when he parked it everything worked fine. The left turn signal front and rear do not work. The bulbs both work. They light up. The right side turn signals do work. The hazard lights only work for the right side. You use the turn signal for the left side they dont blink. The cornering light turns on the turn signals are on but no blinking. THe light on the dash doesnt light up either or blink. You can hear the clicking very faint unlike the right side that can be heard loud and clear. What could be the problem. By my research there is only one flasher module for both sides so wouldnt both sides not work if that failed.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,849
    Re: 1999 SLS Left Turn Signal
    "Light up" - as in: light up when the parking lights are turned on or light up (BRIGHTLY) when the turn signal stalk is pulled to left turn ? (but no flash)
    JimD or N*Caddy will know for sure, but I think the turn signal "clicker" is actually a sound reproduced through the sound system dash speaker(s).
    Study the sticky post just above this - "How to pull codes" - Your car has its own built-in diagnostic code reader/scanner/memory. There may be an electrical or body code set. Use the proper section for your car/year group/button push sequence.
    Google "cadillac forums 1999 seville turn signal problems) and see what that turns up.
    Read the entire Cadillac Technical Archive way up ^^^ in the black bar for other necessary info. Page through threads of interest in Discussions, Item Specific: Cadillac Technical Tips.
    69
    82,273
    I thought that was from the flasher.
  5. #4
    Jun 2013
    25
    10
    Quote Originally Posted by Submariner409 View Post
    The front left yellow turn signal lights up with the parking lights, when I turn the turn signal on the left cornering light lights up the yellow turn signal stays solid. The back left turn signal doesnt even turn on. I checked the bulb in the back and its a good bulb. I even switched the bulb wiring from the left side to the right to check and see if the wiring was messed up but the right continued to work.
    Pulled codes and only one code was current relating to the ambient air temperature sensor
  6. #5
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by JSaunders View Post
    Did you check the bulb with an ohmmeter?
    Do the left side turn signals flash when the Hazard switch is ON?
    Have you checked the LF and LR turn signal bulb sockets for corrosion or burned contacts?
    Have you measured for a pulsing voltage at either the LF or LR turn signal bulb socket contacts?
    I don't understand what you are doing or how you "switched the bulb wiring....".
  7. #6
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    The turn signal/hazard flasher module has in & out wire for both sides separately.
    >>>It's part of the hazard switch.<<<
    I had one with the same symptoms and just moved the connector on the back of the switch & it worked.
    Could also need changing.
  8. #7
    Jun 2013
    25
    10
    Quote Originally Posted by Aztec ETC ECS View Post
    The turn signal/hazard flasher module has in & out wire for both sides separately. It's part of the hazard switch.
    Where is this located and would that also make the left side turn signals not work when the alarm is going off.
  9. #8
    Feb 2012
    NYC
    50
    1,948
    I edited the location above to make it more noticeable.
    And I suppose it could affect the alarm flash too.
  10. #9
    Jun 2013
    25
    10
    Quote Originally Posted by JimD View Post
    No I have no checked the bulbs with an ohmmeter as i do not have one. The front bulbs all work, the turn signal bulb lights up with the DRLs and the cornering light lights up when the turn signal is activated no flashing on dash or bulb and the rear doesnt turn on.
    No the hazard switch doesnt make the left side blinkers work either, they also dont work when the alarm is sounding off.
    I have checked the rear for corrosion/burned contacts, havent on front yet but all the front lights are working.
    I do not have any electrical measuring devices to check any of that.
    What i meant about switching the bulb wiring from was on the rear lights the sockets and the short bit of wiring into the trunk. I switched the left and right side (to see if it was part of that) and the right continued to work. And the left still didnt work
    Is the actual switch and the module seperate or would i have to buy a new switch also.
  11. #10
    Feb 2012
    NYC
    50
    1,948
    ^It's one unit.
    Don't buy a new one 'til you're sure.
  12. #11
    Jun 2013
    25
    10
    SO I would need to buy a new hazard switch and that includes the flasher module. http://shop.advanceautoparts.com/web...=hazard+switch . It is easy to just get that part of the dash out or would i have to take the whole thing apart
  13. #12
    Feb 2006
    56,849
    Talk to Chris in parts at Rippy Cadillac over there >>>>>>
    Leave the Advance parts for the ricer crowd.
    Look at www.alldatadiy.com - subscribe the car - the GM service manuals plus so much more that you need a home study course to find it all.
  14. #13
    Jun 2013
    25
    10
    My father-in-law is a mechanic so Ill let him do it. found http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER for less than any part store in my area. By my research Im going to guess that this is the issue as the left side doesnt work at all, not even on the dashboard.
  15. #14
    Feb 2012
    NYC
    50
    1,948
    $53 is better than $147 but I would still do the "wiggle" test first.
  16. #15
    Jun 2013
    25
    10
    Yah I will once I get into the dash to try it I will but I have to wait till sunday to get into it. No parts store has any on had so I rather have one on hand if the wiggle test doesnt work first. Unless you can point any easy way of getting to the wires to test it.
  • You may not post replies
