2001 SLS Lumbar adjustment troubleshooting
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 SLS Lumbar adjustment troubleshooting in Past Cadillac Vehicle Discussion; Where can I find some info on troubleshooting the drivers side lunbar adjustment circuitry?? The switch does nothing, not up ...
    wrig456 is offline Cadillac Owners Member
    Automobile(s): 2001 Seville sls
    Mar 2010
    73
    4
    The switch does nothing, not up and down or in and out.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: 2001 SLS Lumbar adjustment troubleshooting
    You are in the wrong forum wrig...Try posting over in the Seville/Eldorado forum for better assistance
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,924
    Moved - one day redirect left in "STS".
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Start with the switch.
    I guess form your post the other seat controls work fine so MSM gets power.
    There are 2 motors actuating the lumbar movements:
    Vertical and horizontal (in/out).
    Each motor has a sensor (variable resistor ~10KOhm = potentiometer) and as the motor moves the sensor resistance varies from ~100Ohm to ~10KOhm.
    Even with the sensors disconnected (or malfunctioning) the movement should still happen as long as you use the buttons (but memory feature may not work correctly). You should have MSM codes if the sensors are problematic.
    So you have 5 wires to the lumbar switch (supply and 4 returns up/down/in/out) and these are all connected to the MSM (located underneath the seat. Then form the MSM you have a 10 wire harness going to the lumbar adjustments (2x2 wires for the motor power and 2x3 wires for the sensors).
    Either the harness going to the lumbar motors is having an issue or the lumbar adjustment switch or the harness to it has an issue.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    I keep getting the MSM B2119 code on mine
  8. Remove Advertisements
