No ABS Data, Service Suspension System, Brake Light ABS Light, Traction Control Light
Closed Thread
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, No ABS Data, Service Suspension System, Brake Light ABS Light, Traction Control Light in Past Cadillac Vehicle Discussion; I need some help diagnosing my problem with my 2003 Seville (STS). I suddenly (drove to work fine, left for ...
    asilverblazer's Avatar
    asilverblazer is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Nov 2005
    Oklahoma City
    61
    I need some help diagnosing my problem with my 2003 Seville (STS). I suddenly (drove to work fine, left for lunch bad) have all the warnings listed in the title on the instrument cluster: ABS, Brake and Traction Control lights illuminated, in addition to Service Suspension System.
    Current Codes:
    NO ABS DATA
    DTC P1571 Traction Control Torque Request Circuit
    DTC C0710 Steering Position Signal Malfunction
    DTC U1040 Loss of Class 2 Communications with ABS
    DTC U1000 Class 2 Communication Malfunction
    DTC U1016 Loss of Class 2 Communication with VCM
    I think I am chasing two problems, the steering sensor separate from the brake problem. So, it looks to me like my EBTCM Module has malfunctioned, I checked 2 ABS fuses, one under the hood and one under the rear seat, they were OK. I disconnected and reconnected the EBTCM with no change. What should be my next step?
    The steering sensor looks like I need to replace the sensor, I've been having ongoing intermittent problems with it, now its constant. (Strang coincidence...)
    TIA
    Quick reply to this message Reply
    Nov 2005
    Oklahoma City
    61
    Re: No ABS Data, Service Suspension System, Brake Light ABS Light, Traction Control L
    Looks like this is a ditto of my problem. Guess I'll try this first.
    http://www.cadillacforums.com/forums...iagnosing.html
    Nov 2005
    Oklahoma City
    61
    So I put a used EBTCM on and now I have new codes. DTC C1241 Variable Effort Steering Circuit Malfunction
    DTC C1246 Brake Lining Wear Circuit Open
    Are the EBTCM's model specific? I don't know the specifics of the car it came from. I think it is triggering information it shouldn't, namely to change brake pads, I didn't think this car had that sensor... Not sure on the other one.
    Oh, but at least now the new EBTCM is communicating with the car.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,822
    Your (our) Seville has brake pad wear sensors - at each pad set - all 4 wheels. It's a series circuit - one sensor wears through, the light shows.
    You might want to look at these guys .......... (used EBTCM's can be a crapshoot) ............... http://www.modulemaster.com/en/index.php
    Can't believe I posted that site URL twice in the last half hour ............... and I don't think the EBTCM has anything to do with the Variable Assist Steering (which increases steering wheel effort the faster the car goes)............. It's for more precise steering control at high speeds.
    Nov 2005
    Oklahoma City
    61
    Wow, I haven't seen any wiring, plugs, harnesses whatever for the wear sensors... Where are they? What do they look like? Also my brakes are less than 6 months old, when they needed replaced, the only warning I got was the pad eating up the rotor.
    The ABS module is throwing the C1241 code... Don't know why.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by asilverblazer View Post
    The pad wear sensors are mounted to the backing plate in a notch machined out of the pad material in the inboard pads.
    The picture shows a front pad set for a 1998 Seville and your year/model parts will be similar. The inboard pads are to the right and the ends of the pad wear sensor that mounts in the notch are in front of the high temperature grease package.
    Several possible reasons for that; the pads were not the correct parts and did not include the pad wear sensors, OR a previous owner by passed the pad wear sensor at one or more locations. Who knows what has been done to the brakes on a soon to be eleven year old car?
    Possibly a failed Variable Effort Steering Actuator and almost certainly nothing to do with your brakes situation.
    Nov 2005
    Oklahoma City
    61
    It seems odd that replacing the EBTCM would bring up these new codes. My original EBTCM went out suddenly with no previous codes. Install one from salvage and suddenly these codes? That is the part that doesn't make sense to me.
    I agree who knows, still doesn't explain these sudden problems.
    I don't know what to think about this, I know it likley isn't related, except by the timing of it.
    My manual doesn't say anything about the "Change Brake Pads" either.
    If my car didn't have that and the EBTCM was expecting that circuit to be closed, mine would obviously be open.
    Same thing for the steering code.
    Sep 2003
    Metro ATL
    4,854
    You can take it to the bank that your car left Hamtramck with brake pad wear sensors installed.
    Show us a picture of the front cover of your 'manual".
    Nov 2005
    Oklahoma City
    61
    I use the online manual for my car, the factory one was all tore up.
    I never finished addressing this, because I sold the car.
    Thanks for the help.
  12. Remove Advertisements
Closed Thread
